k-epsilon model with LBM
Old   November 23, 2004, 20:01
Default k-epsilon model with LBM
Sangit
Hi I am a novice in CFD. For my thesis I am implementing k-epsilon model for backward step. So for that reason I am using the the standard Launder and Spalding model with wall function. And I am assigning the boundary values at the first nodes from the wall for k and epsilon. Also I am initializing the initial value of k and epsilon at inlet.
The equation of the boundary values are at 1st nodes from wall : k=utau^^2*sqrt(c_mu) and epsilon=utau^^3/(kappa*delta)
How can i calculate the utau and y+ at the first node. I know that the initial values are valid if 20<y+<100 .And what will be the value of delta as it is the distance from the wall to the 1st node ... in my velocity mesh it is y=1 .... So i am confused .... how can I proceed .... any step by step calculation for utau , y+ and delta will be very much helpful ......
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Compressible epsilon blows up swahono OpenFOAM 10 November 26, 2010 05:38
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
k-epsilon model with LBM Sangit Main CFD Forum 0 November 23, 2004 20:04
K-Epsilon Model sangit Main CFD Forum 2 September 9, 2004 13:19
