Basic Vertex-Based Finite Volume
Old   March 26, 2005, 06:08
Default Basic Vertex-Based Finite Volume
Soheyl
In a cell-centered Finite Volume formulation, the length of cell edges (delta_x and delta_y) are used to calculate the flux. How these lengths are calculated in a vertex-based formulation, especially for an unstructured grid.
Especially consider the case when two vertices have the same x or y coordinate?
Old   March 26, 2005, 07:11
Default Re: Basic Vertex-Based Finite Volume
Srini
Hi If you are looking for info on vertex based unstructured schemes, look for AIAA papers from 88-92 by Tim Barth. He was the pioneer of these methods. Very clearly written papers. Srini
Old   March 26, 2005, 10:03
Jim_Park
You can go further back, to work at Los Alamos in the early 70's. Their ALE methods were based on vertex-cell ideas.
Look for ALE methods in JCP. In the early to mid-70's, look for YACQUI. Around 1980, look for SALE, CONCHAS, and finally KIVA. Investigators - Hirt, Cloutman, Ruppel, Amsden, Ramshaw - and probably some others.
Check the LANL web sites for open literature reports as well. The reports have especially detailed descriptions of differencing schemes, etc.
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Finite Volume Method cfd seeker Main CFD Forum 3 September 8, 2011 04:36
Finite Volume Vs Finite Difference Mukkarum Main CFD Forum 3 February 8, 2003 11:16
Equations for finite difference, element & volume W.L.C. Main CFD Forum 9 April 3, 2001 12:08
