Turbulence in an Injector
Old   April 11, 2005, 18:52
Default Turbulence in an Injector
Casey
I am modeling an injector that has 126 holes. I have the inlet mass flow rate, inlet pressure, outlet pressure, and diameters. When trying to solve for turbulence what type of dissipation rate should I use (length ratio, constant, hydraulic diameter). The flow rate is very low so do I still account for the turbulence? Thanks in advance,
Casey
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
