analyze a cd nozzle with fluent which designed by MOC
Old   July 6, 2011, 04:33
Question how to analyze a cd nozzle with fluent which designed by MOC?
mehrzad
mehrzad is on a distinguished road
hi
i designed a nozzle with method of characteristics with the code which give me the profile of nozzle's wall. now i want to analyze it in fluent. but i do not know how to setup the problem in fluent. the nozzle designed with this condition: inviscid,irrotational,isentropic,2D flow. the question is how to set problem in fluent which can simulate this condition. i found this tutorial and try to setup problem in fluent like this but the result is not close the designed condition for example look at this nozzle wich is designed for mach 1.8 but after the simulation you can see that some region the mach number reached to 2.88
can anyone help me with that to get the proper result from fluent. i just designed the nozzle but i don't have any information about stagnation pressure and temperature, only i have the mach number at the exit and A/A*, P/Po,T/To.
thank you
mehrzad is offline   Reply With Quote
fluent, moc, nozzle
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
For Nozzle fluent problem Jie FLUENT 17 January 11, 2012 13:44
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
how to analyze Chx in fluent Bhushan FLUENT 0 May 9, 2006 05:47
Pressdrop across in nozzle: Fluent Paul Main CFD Forum 8 January 15, 2006 02:24
