May 26, 2005, 11:44 |
problem in solving such an equation
Hi, I have problem in solving such an equation
dy/dt=u(t)-S(r)*[1+(dy/dr)^2] where u(t)=U[1+Vsin(w*t)] We are solving for y(r) and U is an constant =37, V >1. S(r)=S*(r-a)^(1/3) and S is also constant =3.33. Follwing time depedent boundary conditions is used. dy/dt=0 if u(t)>=S(a) dy/dr=0 if u(t)<=S(a) I do not have problem when I solve this equations when V<1. Also I do not have problem when S(r)=S even if V>1. Please help me thanks |
May 27, 2005, 00:48 |
Re: problem in solving such an equation
What kind of numerical scheme are you using to solve the problem ?
-Harish |
May 27, 2005, 03:25 |
Actually I have used CN, Fully implicit and expilcit with back differencing and central differencing schemes.
May 27, 2005, 05:01 |
Have you tried to write down the analytic solution - your pde is only first order so you can write down a general expression for the characteristics - from which you should see the source of your problem!
Also isn't S(a)=0 your boundary condition so that dy/dt = 0 on r=a (I assame r=a is the boundary from your notation). |
May 27, 2005, 07:04 |
I have tried the analytic solutions of such equation. The analytic solution is only possible for the case of V<<1. But the case of V>1 analytical solution is wrong.
Can you give me examples how can analytical solutions helps in such case. Yes you are write about the boundary condition. R |
May 27, 2005, 07:49 |
I'm not sure what you mean by the analytic solution being wrong - unless you mean you tried to obtain a series solution in V<<1? Otherwise the (correct) analytic solution cannot be wrong since it is the solution to the equation!
What I meant by anaytic solution was that you can reduce your pde, using the method of characteristics, to a set of odes for dt/ds, dr/ds, dy/ds dp/ds and dq/ds where p=dy/dt, q=dy/dr and s is the variable along the characteristic. The analytic solution helps for two reasons: (1) It gives something to test your numerics against and (2) If there is a problem with the existence of the solution (i.e. finite time blowup) then you will be able to see why and in what parameter regions it happens. |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
