May 2, 2005, 20:51 |
Pressure BC in SIMPLE
Hi
I am trying to discretize SIMPLE on a staggered grid. It is okay to handle a constant velocity BC since the velocity values at wall are known and that just leads to a zero veloctiy correction at the entrance boundary points. I was wondering what to do with the constant pressure BC. The pressure correction at wall is zero, but we cant place them explicitly in the equation since we are not solving for pressure at wall but only at interior points. Thanks in advance for your responses. Ankan |
May 3, 2005, 06:16 |
Re: Pressure BC in SIMPLE
the boundary condition for the presssure correction equation is the insulation boundary condition . but when you only know the value of the pressur at the boundary ,the value of velocity is unknow.you should use a speciall procedure to convert the pressure to the velocity .you can find it on the <<numerical heat transfer>> thank you
May 3, 2005, 14:10 |
Hi Thanks for your response. Looks like you put in some link for further clarification but it does not seem to be working. I will appreciate if you could post the reference once again.
Ankan |
May 3, 2005, 19:33 |
The pressure correction at the pressure boundary is zero, then you should update the boundary velocity components (or mass flux) using the pressure correction at the boundary and that near the boundary explicitly at each iteration to satisfy the continuity equation. The velocity correction equations for the boundary velocities can be derived as the same way as those in the interior region.
May 3, 2005, 23:40 |
[21] Kanchan and M. Kelkar , Numerical Method for the prediction of incompressible flow and Heat Transfer In Domain With Specified Pressure Boundary Conditions, Numerical Heat Transfer. Part B, vol. 38, pp. 15-36, 2000.
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 02:23 |
Simple pressure difference question | atareen64 | OpenFOAM | 2 | February 2, 2011 04:39 |
Collocated SIMPLE and outlet pressure | yhoarau | Main CFD Forum | 1 | April 16, 2009 09:16 |
Few simple questions concerning boundary conditions (pressure) | milos | OpenFOAM Pre-Processing | 1 | March 21, 2009 07:08 |
Pressure correction on SIMPLE | Diego Nogueira | Main CFD Forum | 6 | October 10, 2004 14:43 |
