August 16, 2011, 02:49 |
Heat transfer coefficient
Daniela
Rep Power: 16 |
Hi
I'm trying to calculate the heat transfer coefficient from my CFD-Simulation. Can anybody tell me which formula I've to implement? I tried using the formula from OpenFoam's application wallHeatFlux, i.e. alphaEff*cp = alphat*cp+lambda divided by the height of the first cell normal to the surface. The units are matching (W/(m^2K)), but my results are way to high. Can anybody tell me where I can find theoretical results/formulas/literature for this topic? Thanks a lot Daniela |
August 16, 2011, 09:02 |
Andrew
Rep Power: 18 |
what are you trying to simulate, and where are you trying to find the convective heat transfer coefficient?
August 16, 2011, 10:17 |
Daniela
Rep Power: 16 |
Hi
I'm using a simple 2D cylinder case to test my calculation of the heat transfer coefficient. Later it will be a cabin flow problem. The coefficient will be used to calibrate 1D simulations. Daniela |
August 16, 2011, 10:30 |
Andrew
Rep Power: 18 |
so, your hand calc is not matching your CFD result? And, it is a cylinder in cross flow?
August 17, 2011, 09:43 |
Daniela
Rep Power: 16 |
I wouldn't expect an exact match, but hand-calc gives 14 and my program gives 626. The difference is certainly to high.There is flow around the cylinder which was considered for the hand-calc.
cfd - post, heat transfer coefficient |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
