the range of wall shear stress
Old   May 27, 2005, 16:51
Default the range of wall shear stress
Sea
Hello guys:
Now I am focusing on the laminar flow. I want to know the range of the shear stress under various conditions, such as separation. Does any book or references talk about it?
Thanks a lot for your nice help!
Sea
Old   May 27, 2005, 17:09
Default Re: the range of wall shear stress
noName
Wall Shear Stress is a linear product of the kinematic viscosity of the fluid and the velocity gradient normal to the wall. It is a sign variable function, and zero crossings usually correspond to separation.
It's best to understand this phenomenon in the boundary layer context. Several books on fluid dynamics discuss the boundary layer on a flat plate and a circular cylinder. An easy to read account is in Kundu,
http://www.amazon.com/exec/obidos/tg...books&n=507846
Old   May 27, 2005, 19:04
Sea
Hi noName,
Thank you very much! I will check that book.
From the definition of wall shear stress, it may be the function of Re number. Can I ask you one more question? How big will the wall shear stress be if Re=1? -0.5, 0.9, or any other values?
Thanks a lot!
Sea
Old   May 28, 2005, 13:48
amol palekar
In case your talking about flat plate, then wall shear can be found as : wall shear stress = (0.644/sqrt(Re_x))*(0.5*rho*U*U)
u may refer viscous fluid flow by frank white or any other text.
Old   May 30, 2005, 11:02
Sea
Hi, amol palekar,
Your message is important for me. I will check these books.
Sea
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 17:11
Specifying shear stress on wall in 5.5.1 michael rasmussen CFX 1 May 19, 2003 09:49
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
plotting wall shear stress Ellen FLUENT 1 April 5, 2002 22:50
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
