intersecting cylinders
Old   June 9, 2003, 12:43
Default intersecting cylinders
m malik
I am trying to develop hexahedral finite element mesh generator for a flow passage having two cylinders of the same diameter that intersect at right angles making a T-joint. Hexahedral mesh in cylinder is a rather simple matter; the mesh in a cylinder comes simply by stitching the qudrangular meshes of circular cross-sections. However, I have problem in creating a compatible mesh at the joint. Any help on this subject will be greatly appreciated. Thanks.
Old   June 12, 2003, 00:27
Default Re: intersecting cylinders
Selina Tracy
It's not difficult as it looks.
First, you need a geometry for T pipe in certain format such as IGES. If you want, I will let you know the place to get the geometry file not only for T but for hundres.
Second, use commercial mesher. I've just made a mesh for + (cross) shape even with nonzero thickness (all hex) It took me less than half an hour.
But when in comes to make a mesh generator, I do not have any idea if it's general purpose.
Good luck.
-Selina
Old   November 2, 2011, 08:25
Default T junction
Aime
akone is on a distinguished road
Hi Selina,
I'd like to create a T joint with two cylinders..Please do you know how I can go about it. I'm very new to ICEM
Thanks in advance!!
akone is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[ICEM] Blocking of 2 cylinders FrankW ANSYS Meshing & Geometry 5 April 14, 2011 10:49
[ICEM] generating tetra mesh on various cylinders at the same time karananand ANSYS Meshing & Geometry 2 July 9, 2010 16:34
[GAMBIT] Hexa meshing two intersecting cylinders in gambit chat1983 ANSYS Meshing & Geometry 0 April 8, 2010 07:38
meshing cylinders Sandra FLUENT 2 July 12, 2005 00:49
