PETSC solvers
Old   December 3, 2011, 18:07
Default PETSC solvers
Mike
saeedi is on a distinguished road
Hi there,
I have a 3-D MPI-FORTRAN parallel code for incomp turbulent flow.
I use multi grid for pressure equation and ADI for momentum.
I want to use the solvers of PTESC (due to their higher efficiency), but I have no experience about PETSC and there is no good tutorial for that (only one manual is avaiable).
So if you have any experience with PETSC, could you please let me know if I only need to call the routines of PETSC (and having the package installed on the cluster) or there is more than that?
Any further useful info. about PETSC is welcome.
(I have worked only with MPI so far)
Thank you so much in advance
saeedi is offline   Reply With Quote
Old   December 4, 2011, 10:13
TWB
quarkz is on a distinguished road
hi, there's actually a lot of examples inside when you download the tar file, although most are in c. but that's how I learn too. if you encounter problems, you can email their user list. Ans are usually given very fast. can check their website for more info.
quarkz is offline   Reply With Quote
Old   December 17, 2011, 07:07
Default Petsc
lalupp
lalupp is on a distinguished road
OPENFVM free cfd code is based on petsc (parallel version)
check its parallel coding
easy to understand
good luck
I Have used petsc but is a heavy weight solver, It seems it needs infiniband
for maximum 2 million cells can u suggest anly light weight parallel solver
lalupp is offline   Reply With Quote
Reaction solvers megacrout OpenFOAM 5 July 8, 2011 10:54
using petsc for large coupled linear systems sd_vakip Main CFD Forum 0 January 31, 2011 12:22
The LESModel for the family of LESmultiphase solvers ngj OpenFOAM Bugs 4 September 23, 2008 18:15
network comms amg solvers bob Main CFD Forum 0 March 1, 2007 19:58
PHOENICS Solvers Hu Phoenics 0 June 28, 2002 07:37
