July 27, 2005, 16:08 |
numerical diffusion in 1D
Hey everyone,
I am wondering something about numerical diffusion - I have a 3D finite volume code that uses the power law discretization for velocity and central differencing for diffusion. For time stepping, I am marching with rk4. As a test case, I have given an initial gaussian along the channel, but with uniform concentration across the channel and no flux boundary conditions across the channel. In other words, a 3D code that has been made 1D for testing purposes. My question is this - Should I expect to see any numerical diffusion? I know that upwinding causes it, and I believe that power law does as well because it too is first order. However, I thought that it only appeared when the flow is diagonal to the grid. I have simply given an axial velocity of 1, and diffusion=0, to see if I can make this gaussian advect. It does, but it also diffuses. The code is perfectly conservative, so I don't think losing concentration to the walls is the problem. Should I expect this? Any possible solutions that would still allow me to keep my power law scheme? Thanks! Jon |
July 30, 2005, 07:14 |
Re: numerical diffusion in 1D
I think numerical diffusion is possible in multidimensional problems only.
July 31, 2005, 22:58 |
Numerical diffusion can and does occur in 1D. If you look at all the classic mathematical descriptions, the analyses are almost always 1D.
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
numerical diffusion in tetrahedral grids | Lilly | Main CFD Forum | 8 | May 31, 2011 10:08 |
Numerical Diffusion in CFX | John S. | CFX | 4 | August 17, 2008 19:47 |
Numerical diffusion. | jinwon | Main CFD Forum | 2 | June 27, 2007 11:42 |
Estimation of numerical diffusion | varghese | FLUENT | 0 | March 24, 2003 05:02 |
