Basics
Old   June 30, 1999, 23:34
Default Basics
Dr. Karsdon
Hello. I am a physician (medical doctor) with hardly a clue about fluid dynamics. A very long time ago I saw something about using fluid like an electrical circuit which could amplify the flow, making it outflow faster than inflow. This done without external energy, using only interconnecting channels. Does anyone have an idea what I am talking about and where can I find some basic references on the subject. Thanks.
Old   June 30, 1999, 23:49
Default Re: Basics
Yogesh Talekar
I think you are talking about a nozzle flow. In nozzle, which is like a symmetric horn, if the incoming flow is slower then out going flow is faster. Same thing can also be achied if you put a oifice (O-ring) inside a pipe. Then the flow after the ring is faster than before the ring.
You can read any book by John D. Anderson, in my opinion he is a GREATE author! bye have a nice day
Old   June 30, 1999, 23:57
Default Re: Basics
John C. Chien
(1). The best place to start your search is the car automatic transmission expert. ( automatic transmission shop) (2). In the automatic transmission, there are complex circuits of small passage for transmission fluid to control the shifting of the transmission. Sometimes, two small side jet ports are used to control the movement of the large main jet in the center by changing the pressure difference in the side jet ports. It is call " fluidic devices" or something like that. It belongs to "hydraulic control" field, I think.
[ANSYS Meshing] The Basics GouldIan ANSYS Meshing & Geometry 0 June 7, 2011 11:10
Questions about the basics of CFX fjj1003 CFX 1 October 29, 2008 10:26
catching up the basics of cfd prajeesh Main CFD Forum 3 August 27, 2006 10:05
basics Pradeep Main CFD Forum 1 March 11, 2005 11:24
basics in cfd tonshal Main CFD Forum 7 November 30, 1999 04:04
