Stability with Under Relaxation factor
Old   June 8, 2019, 05:00
Default Stability with Under Relaxation factor
Arijit Saha
ari003 is on a distinguished road
I was conducting a simulation of two airfoil and the residual monitor at the beginning was showing oscillating behavior. Then I reduced the URF and Explicit relaxation factor too and with successive trial method the residuals got damped. I was doing with k epsilon model and kept the tolerance to be 0.001 for k and epsilon and for x,y velocity and continuity kept 1*10^-6.
All the residuals converged except epsilon. Now my question is which URF value should I change so that the epsilon converge?
And when should I change the explicit residual value?
Note- In a separate monitor the Cl value is almost horizontal irrespective of the non-convergence of the epsilon value.
Will be really helpful if someone replies.
ari003 is offline   Reply With Quote
Suitable range of relaxation factor for VOF boiling cases? manupp STAR-CCM+ 1 February 4, 2020 06:07
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 09:54
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 05:25
What's happening to my solution for lower relaxation factor casesam OpenFOAM Running, Solving & CFD 3 October 22, 2015 01:25
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
