pressure at wall
Old   August 24, 2005, 12:49
Default pressure at wall
Mike
iam solving NS equations using FV code and pressure at wall appeared at my equation. What value should i take for P or how do i discretize dp/dy at a cell near the wall? Is backward differencing ok for pressure? Thank you
Old   August 24, 2005, 14:33
Default Re: pressure at wall
agg
One usually applies dp/dy = 0 at wall (or dp/dn in general)
This is applied while solving the poisson equation.
Example,
The term d2p/dy2 = (pi+1 - 2pi + pi-1)/dy2 ----(A)
At the lower wall, pi-1 is outside the domain; when you apply dp/dy=0 at lower wall i.e (pi+1 - pi-1)/2dy = 0, OR pi-1 = pi+1
Substitute this back in EQ.(A)
Thus, d2p/dy2 = (2pi+1 - 2pi)/dy2
Old   August 24, 2005, 23:11
Praveen. C
Strictly speaking, pressure bc is not required for NS equation. Pressure should come out as part of the solution. But in FV method it may be necessary to specify the pressure for evaluating the wall boundary flux. There are several alternatives that can be used:
1. Extrapolate from inside the computational domain.
2. If you want pressure gradient you can use one-sided differences.
3. Setting normal pressure gradient to zero is only an approximation that is valid for thin boundary layers. A more consistent way to do it is to take the projection of the momentum equation along the normal to the wall to get an equation for the normal pressure gradient.
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Non equilibrium wall function : pressure acquisition problem MafioTia OpenFOAM 1 October 10, 2010 04:45
Wall pressure distribution Karthik FLUENT 0 August 18, 2004 06:53
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
