Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Mesh resolution for modeling flow in a porous media
Old   September 14, 2016, 16:12
Default Mesh resolution for modeling flow in a porous media
Discontinuity is on a distinguished road
Hi
I am doing some work with microfluidic channel and I want to have a much better understanding of how pore voids are filled due to the capillary pumps. As a result I want to actually model the geometry rather than using a global average of the porous zone. I have access to a HPC cluster to run this problem, but I need to get a geometry first. I have access to openfoam, CFX and FLUENT as solvers.
My questions are the following
1) Is there a way to programmatically generate the geometry. I am thinking i want the ability to specify a average size and a SD and have it build a structure that has a normal distribution so I can play with different configurations quickly.
2) Once I have said structure, how many mesh elements do I need in each pore, Say I have a pore size of 3 microns. My mesh must be how many times smaller than that. The channel dimension of the channel is small obviously (140um x 3000um x 3cm) but obviously the more elements the bigger the cpu demand.
Any ideas?
Thanks in advance.
Discontinuity is offline   Reply With Quote
Multiphase flow in porous media and relative permeabilities sirpolar Fluent Multiphase 1 July 24, 2016 05:41
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 09:43
compressible flow through porous media Chirag2302 FLUENT 0 March 2, 2012 23:13
Question for modelling flow in porous media legendyxg FLUENT 9 April 21, 2009 22:24
