Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Setting physical entities with Gmsh using an STL object
Old   March 8, 2021, 07:51
Default Setting physical entities with Gmsh using an STL object
Prapanch Name
Prapanchnair is on a distinguished road
Supppose I have an STL file for a 3d part and I want to apply a boundary condition to a face of it. Note that the STL comes as a single part. Is there a way I can set the physical entities (ID) for a group of nodes that belong to the patch within Gmsh?
For example, I have an part for which I need to to modal analysis with calculix. Can I pick a patch, and assign the nodes of the patch a fixed boundary condition and then use calculix to solve the modes?
If yes, what is the procedure in Gmsh. If you have a video tutorial that you found somewhere, please share that as well.
Thanks and Regards,
PN.
Prapanchnair is offline   Reply With Quote
Old   April 8, 2021, 07:45
France
pavithra Kalarani is on a distinguished road
Hi
I have the same problem.
Have you found any solution for that?.
In my case I have to import into the openfoam.
Thanks and Regards,
Pavithra
pavithra Kalarani is offline   Reply With Quote
boundary condition, gmsh, stl
How to select physical volume in Gmsh Pranto OpenFOAM Pre-Processing 1 August 12, 2023 17:12
GMSH: Access extruded physical geometry BEM Mesh Generation & Pre-Processing 0 November 9, 2020 10:55
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
