Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Salome Exports UNV file with Patches as Facezones Ideas Error
Old   April 22, 2021, 12:53
Default Salome Exports UNV file with Patches as Facezones Ideas Error
Will
wmschultz is on a distinguished road
Hey, I'm trying to do some microfluidics simulations with OpenFOAMS interFoam solver. I made my Geometry in fusion 360 and exported it as a .step to Salome where I mesh it with Netgen Tetrahedrals. My inlet and outlet ports for my application are 2d patches I made in Fusion360, Salome doesn't include these 2d objects in mesh normally, but I can get around this by making the necessary geometry groups, applying the main mesh but not computing it, making a sub mesh of the inlet with NETGEN 2d and computing, then making a 2d projection sub mesh of the outlet port with the reference face as the inlet port and the reference mesh as the main mesh. Then I compute the main mesh and merge any duplicate nodes and elements and it looks like I have a healthy mesh.
However, when I use the IDEAS .unv to foam converter I get an error because the inlet and outlet groups are read as face zones and not patches (I suspect because they are 2d mesh?).
Is there a better way of making a surface patch as an Inlet port besides using the fusion360 surface editor? the surfaces it creates appear to not translate to Salome very well...
I'll attach a barb that i'm using to ensure I can render a stable simulation environment before I complicate my geometry too much. Ill attach a pic of the .unv after I exported it and re-imported it as a mesh back into Salome to look at it. That notice in the object browser was my first hint that something was happening that I didn't understand.
File Type: jpg Screen Shot 2021-04-22 at 12.55.48 PM.jpg (90.3 KB, 12 views)
wmschultz is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
