HyperMesh 3D Hex Solid Mesh: Node-Node Matching/Mapping |
April 21, 2021, 12:42 |
Hey everyone,
I've been trying to mesh hex only (quads only) 2 or 3 fluid domains together using HyperMesh. For the 2 fluid domains, I am able to mesh them, but at there interface, the element faces and nodes are not matched, and I need them to be. For the 3 fluid domains, it fails to mesh them together (specifically the larger domain in between them). I am using the solid mapping option. I need to output them for LS-DYNA, any suggestions? |
3d mesh, hex meshing, hypermesh, ls-dyna |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
[OpenFOAM] ParaView shows bad cells, checkMesh doesn't seem to notice. | CoolHand | ParaView | 2 | August 21, 2014 15:58 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
