May 27, 2021, 01:44 |
Characteristic mesh size in DDES simulation
Mattia Samiolo
Good morning everyone,
I would want your opinion to build the correct mesh around a car, in my case I will use a k-omega SST DDES. I am aware that the measure of the mesh in the boundary condition has to start with a y+ value around 1 because of the SST model, but my concerns arise when the code switch to LES. What calculations or mind path do you use to estimate the mesh in the free stream? As suggested by (Howard and Pourquie), the recommended mesh size in the detached flow regions for a DES-type simulation should be close to the Taylor microscale given by λ = 15^(1/2) A^( -1/2) Re^(-1/2)L, where A is an undetermined constant set to be 0.5 in this paper, L is the bulk integral scale (taken as the vehicle length, L), and Re the Reynolds number Howard and Pourquie paper: https://www.researchgate.net/publica...eference_model Thank you |
ddes, mesh, wake |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
