Home > Forums > Special Topics > Mesh Generation & Pre-Processing
cfMesh noisy mesh
Old   June 1, 2021, 09:27
Default cfMesh noisy mesh
Ingo
Volle is on a distinguished road
Hello
I tested a bit with cfmesh and therefore i created a simple cube in blender, parts of it were exported seperately so i got a merged stl which i turned via surfaceFeaturedEdges -angle 15... into a .fms file.
Now i had a few boundary layers on one side with additional refinement layers and my mesh is kind of very noisy. It even was before the refinement process.
Please have a look at the Dropbox Link for picture.
My meshing settings were really simple and i tried to avoid the automatic refinement process by putting in the minCellSize equal to maxCellSize:
surfaceFile "test.fms";
minCellSize 0.15;
maxCellSize 0.15;
localRefinement
links
additionalRefinementLevels  5;
refinementThickness 0.002;
boundaryLayers
	nLayers 2;
	thicknessRatio 1.2;
	maxFirstLayerThickness 0.003;
patchBoundaryLayers
	links
	nLayers 10;
	thicknessRatio 1.2;
	firstLayerThickness 0.0001;
I do not know why the mesh is so noisy when putting in such a simple geometry..
Would appreciate any help
Best wishes
Ingo
Volle is offline   Reply With Quote
Old   June 11, 2021, 06:51
M
AtoHM is on a distinguished road
If thats paraview, its just visuals. Deactivate "decompose hexahedra" and use crinkle on cuts and planes.
AtoHM is offline   Reply With Quote
Old   June 11, 2021, 19:49
Ingo
Yes that is in paraview.
How can i deactivate it? Even by googling i did not find it..
What is that other thing?
Old   June 14, 2021, 06:37
M
On the .foam-File node in Paraview, below the Point and Cell Data, there should be the switch for decompose polyhedra. If you don't see it, you might need to enable the full settings, by clicking the small "gear" symbol prior to that.
Same for the crincle option, in the properties of a clip or slice look for an option with "crincle".
Sorry I misremembered the naming of the option, its polyhedra not hexahedra.
Old   June 14, 2021, 18:43
Default It worked! :)
Ingo
Actually that property of Polyhedron did not work for this purpose but the crinkle stuff worked, thank you very much
cfmesh, mesh and grid, openfaom-8
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 13:05
[cfMesh] Does cfMesh supports LABEL 64 (integer 64bit) for larger mesh size? lonelywing OpenFOAM Community Contributions 1 August 16, 2019 03:00
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
