Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Criteria for a reactive tubular mesh
Old   June 9, 2021, 11:39
Default Criteria for a reactive tubular mesh
CFDJonas is on a distinguished road
I'm currently working on the CFD simulation of a tubular reactor. The geometry I want to model is astoundingly simple: a long tube with just an inlet, outlet and a wall. No bends, no built-ins, no valves, no injections. The diameter is however rather small compared to the length. Inside the whole reactor a volumetric reaction takes place. During this, my focus is to look at the boundary layer at the wall.
Although this setup seems very easy to generate a mesh from, I'm a little bit overtaxed with which criteria are important for me. My current setup is to have a rectangle with a axial symmetry axis at the reactor center. Do I need inflation layers? Do I only need inflation layers, when I want to incorporate turbulences (but not for laminar flow)? Is it a valid thought, that I need a finer mesh "at the beginning" but a coarse mesh later in the reactor? How does diffusion take an effect when talking about mesh quality? Does a transient simulation of the process require a finer mesh?
What would an ideal mesh look like, for a simple long laminar tube (I know there's analytic solution for this, but I want to take this as an example).
Thanks in advance!
CFDJonas is offline   Reply With Quote
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
