Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
buoyantPimpleFoam - no relaxation
Old   January 14, 2014, 17:06
Default buoyantPimpleFoam - no relaxation
Tobi's Avatar
Tobias Holzmann
maybe I found a bug in the buoyantPimpleFoam solver.
Information:
  • small case (2D - wedged)
  • closed volume
  • T initialized with setFields
  • dt = 1e-8
  • save date all 1e-8 (so every iteration)
1. Step
  • No relaxation factors in fvSolution
  • I get 24 iterations
  • after that simulation blow up
2. Step
  • added relaxation to fvSolution
  • After 24 iterations the simulation blow up
3. Step
  • relax factors to 0.001
  • Solution in paraview like Step 1 and 2
4. Step
  • relax factors changed to 1e5
  • Solution in paraview like 1, 2 and 3
So in my opinion the relaxation factors are not taken into accout because if I set the factors to 1e5 I should never reach the second/third iteration, arent I ?
Additionally I had a look into the code - relaxation is included:
    EEqn.relax();
    pEqn.relax();
    UEqn.relax();
So now the question is, why I get always same solutions if I change the relaxation factors - thats not correct.
If I change the factors in simpleFoam to 100 the simulation blow up at the beginning.
Thanks in advance
Tobi
Old   January 14, 2014, 17:14
Default Solved
Tobi's Avatar
Tobias Holzmann
sometimes people should go to bed if they are tierd.
The relaxation is working - I just made a mistake in the relaxation declaration with "Final" ...
@Mod - this thread can be deleted.
Thanks for reading and sorry for "spaming"
Regards Tobi
buoyantPimpleFoam Convergence Issues joel.lehikoinen OpenFOAM 1 December 5, 2013 14:58
Relaxation and convergence sammi Phoenics 0 March 20, 2008 03:32
relaxation parameter rvndr Main CFD Forum 0 May 5, 2004 12:34
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
