Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Error on biomassGasificationFoam_installPack_1.0
Like Tree1Likes
  • 1 Post By sante
Old   May 19, 2017, 15:48
Default Error on biomassGasificationFoam_installPack_1.0
Kadiri is on a distinguished road
I am trying to test the solver biomassGasificationFoam version 1.0 developed on OpenFoam 2.1.1.
I use OpenFoam 4.1 and when I compile this solver I have this first error :
porousReactingZone.H:269:34: error: ‘const class Foam::coordinateSystem’ has no member named ‘axis’
return coordSys_.axis();
Can anyone help me please.
Kadiri is offline   Reply With Quote
Old   May 23, 2018, 15:27
sante junior
sante is on a distinguished road
install of211
sante is offline   Reply With Quote
Old   September 16, 2018, 02:18
Question Installation error in biomassGasificationFOAM on OpenFOAM version 2.1.1
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Foamers,
Hope you are doing good. I have come to know higher versions in OpenFOAM have different OpenFOAM libraries and ODE, which doesn't suit biomassGasificationFoam module.
So, I installed of211 to setup the biomassGasificationFoam. However, it leads to error. And again, I followed link below explaning axis code snippet -- still leading to the error.
https://www.researchgate.net/post/Ca...nFoam_versions
And attachment here - terminal window threads after installation, where I can find some noticeable words like "ERROR" and "FAILED" in a few areas. Literally, I couldn't able to figure out what it is.
I have searched all around forums and googled about it - no info regarding this installation...
Could someone please help me to find the solution for this installation
Thank you in advance..^^
Kummi is offline   Reply With Quote
Old   September 16, 2018, 13:23
Kumaresh
Answer figured out and posted ~~ in the following link
BiomassGasificationFoam compiling issue
Old   September 16, 2018, 18:52
sante junior
Hi Kumaresh
it's been a long time that I try to install this solver but without success. And thank you for the link; I'm going to try...
Kummi likes this.
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer Melvin FLUENT 2 November 17, 2016 01:06
