Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Is it a bug of Lee.C in icoReactingMultiphaseInterFoam?
Like Tree12Likes
  • 7 Post By MamoruTamura
  • 5 Post By MamoruTamura
Old   November 10, 2020, 15:56
Default Is it a bug of Lee.C in icoReactingMultiphaseInterFoam?
Mamoru Tamura
MamoruTamura is on a distinguished road
Hello everyone,
I am trying a simulation of melting and solidification of matter, using icoReactingMultiphaseInterFoam in OpenFOAM v2006.
However, I found a phenomenon which seems to be a bug.
Since I'm a beginner of OpenFOAM, please let me consult about this.
To come to the point, I guessed there is a quite simple bug of a minus sign in Lee.C.
My simulation files are attached.
solidMelting2D_heating_cooling.zip
To try a simulation, I refered a tutorial of solidMelting2D, and changed its parameters, as follows.
In system/controlDict, endTime and writeInterval were changed,
endTime         200;
writeInterval   2;
In 0/T, left and right boundaryField were changed,
internalField   uniform 301.3;
boundaryField
    left
    	type externalWallHeatFluxTemperature;
        mode power;
        Q table
            (0      1000)
            (50     1000)
            (50.01  -1000)
            (100    -1000)
        kappaMethod fluidThermo;
        value $internalField;
    right
        type           fixedValue;
In constant/phaseProperties, massTransferModel for a phase change from liquid to solid was add,
massTransferModel
    (solid to liquid)
        type            Lee;
        C               40;
        Tactivate       302.78;
    (liquid to solid)
        type            Lee;
        C               -40;
        Tactivate       302.78;
I changed the left boundary condition of T, to heat their with 1000W for the first 50 seconds, and after that, cool their with -1000W.
Thus, we can expect the melt and solidification of matter.
This is a result of simuation, alpha.solid is shown.
First, as expected, the matter showed a melt.
However, in the middle of simulation (after t = 36s), the simulation showed a strange behavior.
I think there is a bug in the KSu function of Lee.C, because of the following reason.
For a different purpose, I investigated the latent heat calculation in icoReactingMultiphaseInterFoam.
It is calculated in the heatTransfer function of MassTransferPhaseSystem.C, whose line 294 is,
                eqn -= fvm::Sp(Sp*L.ref(), T) + Su*L.ref();
these Sp and Su would be from Lee class.
In Lee.C, KSp function calculates,
         volScalarField from
             min(max(this->pair().from(), scalar(0)), scalar(1))
         const volScalarField coeff
             C_*from*this->pair().from().rho()*pos(from - alphaMin_)
             /Tactivate_
         if (sign(C_.value()) > 0)
             return
                 coeff*pos(refValue - Tactivate_)
         else
             return
                 coeff*pos(Tactivate_ - refValue)
and KSu function calculates,
         volScalarField from
             return
                 -coeff*pos(refValue - Tactivate_)
         else
             return
For C > 0 (phase change from solid to liquid), these functions are,
S_p = C\alpha\rho/T_A
S_u = -C\alpha\rho
for T_A < T
Thus, the above mentioned MassTransferPhaseSystem.C line 294 would be,
eqn -= \dot{m}L
\dot{m}L = (S_p T+S_u)L = C\rho\alpha\frac{T-T_A}{T_A}L
which describes the energy source due to the mass change of phase change, and the mass change \dot{m} corresponds to the Lee model explained in,
https://www.openfoam.com/releases/op...nd-physics.php
On the other hand, for C < 0 (phase change from liquid to solid), from above Lee.C code, Sp and Su are calculated as,
S_u = C\alpha\rho
for T < T_A
There is not a minus sign in Su calculation, thus, the sign of Sp and Su are identical; MassTransferPhaseSystem.C line 294 would be,
eqn -= \dot{m}L
\dot{m}L = (S_p T+S_u)L = C\rho\alpha\frac{T+T_A}{T_A}L
which is different with the Lee model shown in above link.
I guessed a minus sign is required in Su also for C < 0, like as,
S_u = -C\alpha\rho
and the C < 0 case of KSu function should be,
         else
             return
                 -coeff*pos(Tactivate_ - refValue)
After this modification, I compiled icoReactingMultiphaseInterFoam, and retried the simulation.
This is a result.
As expected initially, the matter showed the melt and solidification.
I think the simulation was successful.
Let me hear what you think.
Best regards,
Mamoru
MamoruTamura is offline   Reply With Quote
Old   December 2, 2020, 21:51
Mamoru Tamura
For this topic, I reported on
https://develop.openfoam.com/Develop.../-/issues/1934
It was solved.
Thanks!
olesen, snak, TeresaT and 2 others like this.
mapFields major bug alchem OpenFOAM Bugs 14 September 15, 2023 12:48
Bug in Workbench CFX Pierre1 CFX 6 August 2, 2017 00:18
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 08:15
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 10:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 10:22
