Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Supercritical flow
Old   August 17, 2021, 01:27
Default Supercritical flow
Piedao-Chuan
chang_zc is on a distinguished road
This is a supercritical flow (O2 、H2), but it always diverges in the calculation process:疯狂的::疯狂的:. I hope you can give me some suggestions. Thank you very much.
Courant Number mean: 2.51125 max: 18.699
Time = 0.0003855
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
min/max(U)) = 0, 149.098
update D with binary diffusion model...
species transprotation equation
DILUPBiCG: Solving for O2, Initial residual = 0.00116254, Final residual = 2.02936e-06, No Iterations 3
DILUPBiCG: Solving for H2, Initial residual = 0.000823762, Final residual = 5.40367e-07, No Iterations 3
Calculating inert species N2
Solving energy equation
DILUPBiCG: Solving for h, Initial residual = 0.00355332, Final residual = 4.344e-09, No Iterations 6
Starting correcting themo
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 in "/lib/x86_64-linux-gnu/libm.so.6"
#4 pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foam::PengRobinson<Foam::realGasSpecie>::Z(double, double) const at ??:?
#6 Foam::realGasJanafThermo<Foam::PengRobinson<Foam:: realGasSpecie> >::cp(double, double) const at ??:?
#7 Foam::realGasHePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::realGasReactingMixture<F oam::ChungHighPressureTransport<Foam::species::rea lGasThermo<Foam::realGasJanafThermo<Foam::PengRobi nson<Foam::realGasSpecie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:?
#8 Foam::realGasHePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::realGasReactingMixture<F oam::ChungHighPressureTransport<Foam::species::rea lGasThermo<Foam::realGasJanafThermo<Foam::PengRobi nson<Foam::realGasSpecie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:?
at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
at ??:?
chang_zc is offline   Reply With Quote
Old   August 17, 2021, 12:28
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You should not have Courant numbers beyond 1. I recommend even lower values.
Use the automatic time step control which ensures that.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 18, 2021, 05:34
Piedao-Chuan
Thank you very much. I have made changes based on your suggestion. Unfortunately, the result is still divergent.
Courant Number mean: 0.0499972 max: 0.11485
Time = 0.00164182
min/max(U)) = 0, 43.6587
DILUPBiCG: Solving for O2, Initial residual = 4.01292e-06, Final residual = 6.74252e-19, No Iterations 3
DILUPBiCG: Solving for H2, Initial residual = 3.93064e-06, Final residual = 2.12152e-18, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 2.2811e-05, Final residual = 1.54394e-10, No Iterations 3
at ??:?
#11
at ??:?
浮点数例外 (核心已转储)
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 05:21
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Modelling transonic 2D flow over supercritical air Teddy FLUENT 0 November 20, 2007 17:03
