January 27, 2009, 08:28 |
I was working on a
Sébastien Bocquet
I was working on a turbulent flat plate with the Spalart Allmaras model, and the results were not fine. So I had a look at the source code and I think there is something wrong. The version implemented in openFOAM 1.5 is the Spalart Allmaras with fv3 function. This version also requires to modify fv2, which is not done (the correct fv2 consistent with the use of fv3 is on the commented line) : tmp<volscalarfield> SpalartAllmaras::fv2 ( const volScalarField& chi, const volScalarField& fv1 ) const { return 1.0 - chi/(1.0 + chi*fv1); //return 1.0/pow3(scalar(1) + chi/Cv2); } Thus I think either the commented fv2 should be used keeping fv3 unchanged, or fv3 should be set to 1, keeping fv2 unchanged. For testing, I did the latter, removing fv3 in the expression for Stilda, which gives the basic form of Spalart Allmaras model : volScalarField Stilda = sqrt(2.0)*mag(skew(fvc::grad(U_))) + fv2(chi, fv1)*nuTilda_/sqr(kappa_*d_); After recompiling, the velocity profiles and local friction agree very well with theory and other CFD codes. Seb |
January 27, 2009, 09:59 |
Thanks for studying this code
Rep Power: 22 |
Thanks for studying this code in detail and for the bug report, yes you are correct, this is currently inconsistent. We originally implemented the standard SA model and it worked well for simple cases but when we moved to complex problems, in particular F1 cars, it proved unstable. We then implemented the "correction" from
"An Unstructured Grid Generation and Adaptive Solution Technique for High Reynolds Number Compressible Flows" G.A. Ashford, Ph.D. thesis, University of Michigan, 1996. and this proved much more stable. However it looks like while switching between the models at some point the fv2 has been left inconsistent with fv3. Could you please check if you get the correct behavior with the alternative fv2 and fv3? Thanks H |
January 27, 2009, 10:25 |
Yes I will check with the fv3
Sébastien Bocquet
Yes I will check with the fv3 version.
My test cases are however simpler than F1 cars (flat plate and backward facing step). The fv3 version seems to be corrected for low Re flows, at least from this source : http://turbmodels.larc.nasa.gov/spalart.html Thanks for your comment on SA instability. Seb |
January 27, 2009, 10:33 |
The LES versions of the Spalar
Eugene de Villiers
Rep Power: 21 |
The LES versions of the Spalart-Allmaras model do have the correct implementation and exhibit what appears to be the correct behaviour.
Eugene |
January 27, 2009, 11:00 |
Hi Sébastien,
Thanks for th
Rep Power: 22 |
Hi Sébastien,
Thanks for the interesting link, it seems they are not very happy with the fv3 term: " It was devised to prevent negative values of the source term, and is not recommended because of unusual transition behavior at low Reynolds numbers (see Spalart, P. R., AIAA 2000-2306, 2000)." but the source term going negative does happen in complex flow cases and causes nuTilda to go negative! so we need a fix of some kind. It is not clear if any of the alternative formulations are preferable, perhaps the SA-Edwards or SA-salsa are better; at least they both have a well-posed generation term. H |
February 16, 2010, 16:47 |
#6 | |
Charles Mockett
Thanks for this interesting and important discussion. I brushed with this issue recently, when implementing the original SA formulation in our in-house solver: I found the same stability problem in very specific regions of the flow in a "slightly complex" test case. I contacted the model authors and they recommended some additional limiters to prevent Stilde from reaching zero or going negative, which fixes this problem. The limiter we implemented is: chi >= 1E-03 sTilde >= 1E-05*U_ref/L_ref (we have a user-defined reference length and velocity, however it is simply important to make sure sTilde doesn't reach zero). After that discussion, the LaRC web page you have cited was updated with a one-line note at the end of the original SA model description. I wouldn't recommend the SA-Edwards model, as contrary to the authors' intention, it doesn't give the same results as the original model (rather, significantly reduced skin friction). My hope is that by implementing the original SA with these limiters, you will be able to keep the model to a single, all-purpose variant that corresponds to the "industry standard". Best regards, Charlie. |
February 17, 2010, 04:55 |
Rep Power: 22 |
I am not a big fan of clipping; I would prefer an approach where the formulation of the terms naturally obey the physical constraints. Do you have results that show that the original formulation with the clipping is better than the "Ashford" correction we currently use and distribute with OpenFOAM?
H |
February 17, 2010, 11:37 |
Charles Mockett
Dear Henry,
I understand and share your concern - these things are certainly "not nice". However, in this case I was happy with the modification, for the following reasons:
Now to your question: Do you have results that show that the original formulation with the clipping is better than the "Ashford" correction we currently use and distribute with OpenFOAM? I'm not familiar with the "Ashford" correction and didn't manage to find the PhD thesis easily, but assume this refers to the f_v3 modification. The f_v3 was by the way proposed by Spalart as an attempt to fix the problem of negative sTilde without clipping. I don't have results to show that the original+clipping is better than f_v3, since I haven't tried f_v3. All I have are citations that discourage the use of f_v3, for example Spalart writes in "Trends in Turbulence Treatments" (AIAA 2000-2306): "...the f_v3 function, which we have recommended privately to some users. The f_v3 formula has an odd effect on transition at low Reynolds numbers, which we never fully understood. It was devised to prevent negative values of sTilde. We now recommend, instead, taking for sTilde the larger of the original f_v1 definition and 0.3 x S." So, in summary, I just have "hearsay" and no concrete results of my own to say that one is better than the other. However, reputable and authoritative sources discourage the use of the unpublished f_v3. I would therefore personally be happier to see the original model with clipping as the standard OpenFOAM implementation. However, due to the source code acces it would of course be no problem for me to implement my preferred version should you decide to go for f_v3! I hope this information is useful. Best regards, Charlie. |
January 27, 2009, 12:01 |
Thanks Sébastien,
I was als
Etienne Lorriaux
Thanks Sébastien,
I was also getting unbelievable results on a train drag computation case with SpalartAllmaras. Since the results are satisfaying with a RNGkEps model, I was also thinking to look after the SA coeffs. You found the problem before me, thanks ;) I'll try to run the case again as soon as I have free CPU time. Bye, Etienne. |
January 27, 2009, 16:23 |
I have pushed the change to fv
Rep Power: 22 |
I have pushed the change to fv2 to OpenFOAM-1.5.x, please let me know if this resolves the issues with this model.
Thanks H |
January 27, 2009, 18:26 |
I agree that the fv3 term need
#11 |
I agree that the fv3 term needs to be blitzed. I did a little study of this about a year ago. Here are a couple of figures to highlight the effect of turning this term off.
January 28, 2009, 03:18 |
In these comparisons did you c
#12 |
Rep Power: 22 |
In these comparisons did you check that the fv2 term was set consistently for the cases with and without the fv3 term? The initial comparisons we did after introducing the fv3 term showed very similar results to the standard model but with improved stability which is why we kept it. Unfortunately at some point since then the fv2 has been set inconsistently with the fv3 term; this is now fixed in 1.5.x.
I would be more than happy to drop the fv3 term if a form of the SA model can be found which does not suffer from the stability problems related to negative production in the original model. Has anyone tested the many variants? They are pretty easy to implement and I would be happy to add the promising ones to the set of turbulence models in OpenFOAM if there is interest. H |
January 28, 2009, 07:05 |
Henry,
These plots were mad
#13 |
Henry,
These plots were made doing exactly what Sebastien suggested in the original post of this thread, i.e., setting fv3 = 1, and keeping fv2 as implemented. This should give the original SA formulation. Around the same time, I did a study of ALL of the RANS turbulence models for turbulent flat plate boundary layer, and found that most of them give poor results. Here is a plot of some of them. SA with fv3=1 and LaunderSharma give pretty good results. LienCubicLowRe (including a few mods that I tested) gives horrible results. kEpsilon with wall functions is OK, as long as user is careful to avoid outer part of buffer layer (cf. y+ 30 vs. 115). The take away points from this study were: 1. be very careful if accurate prediction of wall-shear stress (and drag) is required. SA and LaunderSharma seem to do the best. Menter's kOmegaSST (no wall functions) that was out on the wiki also does a pretty good job (has that been adopted in 1.5?). 2. just because there are models in OpenFOAM, doesn't imply that they have been validated for your problem. BUYER BEWARE.... 3. OpenFOAM sorely needs adaptive wall functions which can seemlessly transition from sublayer resolution to wall-function resolution. Eric |
January 28, 2009, 07:16 |
When you ran with fv3 != 1 cou
#16 |
Rep Power: 22 |
When you ran with fv3 != 1 could you clarify which form of fv2 you running with?
H |
January 28, 2009, 07:20 |
tmp
#18 |
( const volScalarField& chi, const volScalarField& fv1 ) const { return 1.0 - chi/(1.0 + chi*fv1); //return pow(scalar(1) + chi/Cv2, -3); } |
January 28, 2009, 07:28 |
That form is correct for fv3 =
#19 |
Rep Power: 22 |
That form is correct for fv3 = 1 but to run with fv3 != 1 you will need to run with the second expression commented out, see the original post. If you have time to test this that would be great.
H |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
SpalartAllmaras question | egp | OpenFOAM Running, Solving & CFD | 45 | October 28, 2010 03:30 |
SpalartAllmaras DES question | ivan_cozza | OpenFOAM Running, Solving & CFD | 0 | December 15, 2008 06:34 |
YPlus for SpalartAllmaras | ddigrask | OpenFOAM Running, Solving & CFD | 1 | December 12, 2008 14:29 |
Pow in lib64tlslibmso6 SigFpe when running coodles with SpalartAllmaras | lillberg | OpenFOAM Bugs | 4 | December 7, 2007 08:17 |
