Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
1712 finiteArea Parallel bug?
Old   February 9, 2018, 10:06
Default 1712 finiteArea Parallel bug?
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
Hi everyone,
I'm uncertain if this is a bug or if parallel running hasn't been implemented for the finiteArea method in 1712 yet.
Whenever I try to run one of the finiteArea solvers in parallel I get the following error (I know it isn't at all helpful but its all i've got):
[ceg-w617:9451] *** An error occurred in MPI_Recv
[ceg-w617:9451] *** reported by process [2378104833,0]
[ceg-w617:9451] *** on communicator MPI_COMM_WORLD
[ceg-w617:9451] *** MPI_ERR_TRUNCATE: message truncated
[ceg-w617:9451] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[ceg-w617:9451] ***    and potentially your MPI job)
[ceg-w617:9452] *** An error occurred in MPI_Recv
[ceg-w617:9452] *** reported by process [2378104833,1]
[ceg-w617:9452] *** on communicator MPI_COMM_WORLD
[ceg-w617:9452] *** MPI_ERR_TRUNCATE: message truncated
[ceg-w617:9452] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[ceg-w617:9452] ***    and potentially your MPI job)
Thanks
Andy
Andrew.Coughtrie is offline   Reply With Quote
Old   February 14, 2018, 11:02
Smile 64 Bit Labels
Andrew Coughtrie
Seems to work fine when I recompile with 32bit labels
Andy
finite area method, mpi error, parallel
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Is there a bug when running createBaffles in parallel??? zfaraday OpenFOAM Pre-Processing 1 May 12, 2015 13:32
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 28, 2013 23:44
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM 0 May 21, 2009 00:23
