Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Canbt install on Suse 102
Old   December 1, 2007, 14:11
Default I am using Suse Linux 10.2 wit
Klaus
klausb will become famous soon enough
I am using Suse Linux 10.2 with the latest online updates on an Intel Core2
I tried to install OpenFoam according to the instructions found on http://www.opencfd.co.uk/openfoam/linux.html and encountered two problems:
1. The files ending .gtgz can't be extracted > basically resolved by renaming the file ending to .tgz
2. When I try to extract all the installation files in the suggested file structure $HOME/OpenFoam/linux as described on http://www.opencfd.co.uk/openfoam/linux.html, the files OpenFOAM-1.4.1.linuxGccDPOpt.gtgz and OpenFOAM-1.4.1.linuxGccSPOpt.gtgz can't be extracted after OpenFOAM-1.4.1.General.gtgz (all these files now ending .tgz so they can be extracted at all) producing an error message "mv: moving „/home/user/OpenFoam/OpenFOAM-1.4.1.linuxGccDPOpt.tgz_FILES/OpenFOAM-1.4.1" to „/home/user/OpenFoam/OpenFOAM-1.4.1" not possible: The directory is not empty
What can I do about it?
Klaus
klausb is offline   Reply With Quote
Old   December 1, 2007, 20:05
Default Hi The steps I usually do t
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hi
The steps I usually do to install OpenFOAM are:
mkdir ~/OpenFOAM
mkdir ~/OpenFOAM/linux
copy OpenFOAM-1.4.1* files to OpenFOAM, and gcc, paraview and java to linux
cd ~/OpenFOAM
tar xzf OpenFOAM-1.4.1.General.gtgz
tar xzf OpenFOAM-1.4.1.linuxGccDPOpt.gtgz
cd ~/OpenFOAM/linux
tar xzf gcc*
tar xzf paraview*
tar xzf java*
edit ~/.bashrc and add at the bottom of the file:
. /home/jose/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
With this, OpenFOAM is up and running. Please re-try your installation, and tell us if you solved your problem.
Regards,
José Santos
santos is offline   Reply With Quote
Canbt start a new thread cwang5 OpenFOAM 1 January 14, 2009 05:21
Why canbt I view the change of U ivanyao OpenFOAM Running, Solving & CFD 0 January 3, 2009 23:01
[OpenFOAM] Help streamline canbt be shown alice ParaView 6 November 4, 2008 03:49
Install Openfoam in Suse 100 setup environment h34gk1 OpenFOAM Installation 1 September 26, 2006 20:08
Canbt run the tutorial cavity fengxs OpenFOAM Installation 4 May 10, 2005 13:18
