Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
ReadCHEMKINIII donbt work
Old   August 23, 2007, 11:07
Default I build readCHEMKINIII contain
Marco Moscaritolo
mavimo is on a distinguished road
I build readCHEMKINIII contained into folder ~/OpenFOAM/OpenFOAM 1.4/applications/test/readCHEMKINIII, but if I ran it with all chemical mechanism it fall with this error:
--> FOAM FATAL ERROR : bad size -1214448268
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::List<foam::reaction<foam::sutherlandtranspor t<foam::speciethermo<foam::jan afthermo<foam::perfectgas> > > >*>::List(int)
#3 Foam::PtrList<foam::reaction<foam::sutherlandtrans port<foam::speciethermo<foam:: janafthermo<foam::perfectgas> > > > >::PtrList(Foam::SLPtrList<foam::reaction<foam::su therlandtransport<foam::specie thermo<foam::janafthermo<foam::perfectgas> > > > > const&)
#4 main
#5 __libc_start_main
#6 __gxx_personality_v0
From function List<t>::List(const label size)
in file /home/simulation/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/List.C at line 54.
FOAM aborting
Aborted
If I run readCHEMKINIII contained into OpenFOAM 1.3 with mechanism and thermal files they don't produce error.
bye
Marco
mavimo is offline   Reply With Quote
Old   August 23, 2007, 11:49
Default I just tried readCHEMKINII
henry is on a distinguished road
I just tried
readCHEMKINIII CHEMKINdata/chem.inp_c7h16 -thermo CHEMKINdata/therm.dat
in version 1.4.1 and it ran fine.
henry is offline   Reply With Quote
I donbt understand antopnieta OpenFOAM Running, Solving & CFD 1 January 15, 2008 14:44
I donbt want to use wall funtions How can I do it pablo OpenFOAM Running, Solving & CFD 3 July 29, 2006 17:48
[blockMesh] Binary mode donbt work fabianpk OpenFOAM Meshing & Mesh Conversion 5 May 21, 2006 11:17
FoamX donbt show some cases derath OpenFOAM Pre-Processing 1 April 28, 2006 13:16
Donbt save bak adorean OpenFOAM 0 March 10, 2005 04:52
