Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
nonNewtonianIcoFoam - problem with parallel run
Old   April 1, 2009, 03:48
Default nonNewtonianIcoFoam - problem with parallel run
Chris
chris_sev is on a distinguished road
Hallo,
When I run nonNewtonianIcoFoam in parallel transient results are not beeing written on nodes other than master.
I have never experienced this in case of other solvers. I am sure that I didn't messed with settings because when I use other solver for the same simulation and number of processors everything works fine.
Is that bug?
chris_sev is offline   Reply With Quote
Old   April 1, 2009, 05:16
Mattijs Janssens
I cannot repeat this with the offsetCylinder tutorial.
All the field writing is done in the same way regardless of the solver so it is unlikely it is a problem of nonNewtonianIcoFoam itself. Is your problem only for one case or also for the tutorial case?
Old   April 1, 2009, 07:10
Chris
Hi Mattijs,
Thanks a lot for response.
With tutorial case (offsetCylinder) it's the same. I've just checked this, used 2computers with 2 processors on each.
I got transient results only on my master machine (processor0 and processor1).
I am using standard nonNewtonianIcoFoam that comes with installations package. I didn't played with the code (apart from implementation of time step adjustment).
I am using 1.5 version.
Do you have any ideas/hints ?
Thanks in advance,
Chris
Old   April 1, 2009, 07:32
Mattijs Janssens
Run all (4?) your processes on your local computer and check. Maybe your second computer does not allow writing to the disk.
Switch on debug flag for objectRegistry. You'll get messages from all processors of the form
objectRegistry::write() : Considering writing object ...
Old   April 1, 2009, 09:13
Chris
I am not very familiar with parallel run in OF so i don't realy know what does it mean and how to manage this:
But anyway thanks for help. I am sure it's helpfull, so now I will search through the forum trying to figure out what's the meaning of above
I am wondering also how it's possible that other computer doesn't allow to write data when use nonNewtonianIcoFoam but when use rasInterFoam everything is fine :/
Chris
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Cannot run Star-CCM+ parallel in Linux dburns Siemens 9 April 27, 2010 12:01
Parallel run with engineFoam francesco OpenFOAM Bugs 1 November 25, 2008 07:06
Moving Mesh Run problem - Scientific Linux G. SE Siemens 2 May 7, 2008 07:15
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
