Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
bugs in moleculeDynamics model?
Old   May 8, 2009, 19:33
Default bugs in moleculeDynamics model?
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Dear foamers
there seems two bugs in the following two files
(1)file : moleculeCloudBuildDirectInteractionList.H: line 13
location: src/lagrangian/molecularDynamics/molecule/moleculeCloud
if face f is a boundary face, it hasn't a neighbour face and the operation of mesh_.faceNeighbour()[f] will exceed the array bound.
A possible solution is moving this line of code to line 40 in that file.
(2) file: pairPotential.C : line 148 and line 111
location: /src/lagrangian/molecularDynamics/potential/pairPotential/basic/
In function of forceLookup, if r=rCut, k=N-1;
and energyLookup[k+1] or will exceed the array bound.
It seems that the size of lookupTable definition is wrong.
In line pairPotential.C:82
label N = label((rCut_ - rMin_)/dr_) + 1;
should be changed to
label N = label((rCut_ - rMin_)/dr_) + 2;
Junwei
su_junwei is offline   Reply With Quote
Old   May 18, 2009, 09:00
Graham Macpherson
gmacpherson is on a distinguished road
Hi Junwei,
Thanks for spotting these. Both fixes have been made in 1.5.x.
1) Correct, I've moved the the neighbour cell label declaration within
if (mesh.isInternalFace(f))
as you suggest.
2) This has been fixed in pairPotentialList.C by making the cut-off radius test
if (rIJMagSqr < rCutSqr(a, b))
instead of
if (rIJMagSqr <= rCutSqr(a, b))
so it is not possible for r=rCut when the potential is evaluated. This is now in line with what's in the MD books by Allen & Tildesley and Rapaport who use U(r) = 0 when r >= rCut.
Regards,
Graham
gmacpherson is offline   Reply With Quote
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 January 8, 2001 15:49
references about the fan/radiator model Mihai ARGHIR FLUENT 0 December 21, 2000 03:07
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 0 December 21, 2000 03:06
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 December 17, 2000 07:01
references about the fan/radiator model Mihai ARGHIR FLUENT 0 December 17, 2000 06:40
