Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Debugging a segmentation fault?
Old   July 4, 2009, 01:19
Default Debugging a segmentation fault?
Steve Hansel
hansel is on a distinguished road
I'm having a problem with at segmentation fault in turbDyMFoam. I'm attempting a rotating mesh and something about moving that mesh is causing the fault, with no error or warning message. I would like to gather more information on the cause of the fault.
I can fire up GDB and get the name of the routines it was in, but that's not very useful. I have 2 questions:
1) Is there an option to turbDyMFoam to give more debugging information?
2) Is there an easy way to compile in debug mode. I have developed unix (solaris) code, but I only used makefiles. These huge trees with wmakes and cmakes are strange to me. Is there a master options list somewhere?
Thanks
Steve
hansel is offline   Reply With Quote
Old   July 6, 2009, 04:45
Henrik Rusche
henrik is on a distinguished road
Dear Steve,
in $FOAM_SRC/../etc/cshrc you find
# WM_COMPILE_OPTION = Opt | Debug | Prof
if ( ! $?WM_COMPILE_OPTION ) setenv WM_COMPILE_OPTION Opt
#if ( ! $?WM_COMPILE_OPTION ) setenv WM_COMPILE_OPTION Debug
#setenv WM_COMPILE_OPTION Opt
Uncomment the last line. Resource. Make sure WM_COMPILE_OPTION is set correctly. Compile Everything. Compile your code.
This adds full debug information to your library and executables which you can use "gdb" OR "valgrind --tool=memcheck" on. I find the latter very useful for finding memory violations.
Here are also a few links that I found quickly after googling "openfoam debugging".
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/debugging.pdf
http://openfoamwiki.net/index.php/HowTo_debugging
http://powerlab.fsb.hr/ped/kturbo/Op...ngTraining.pdf
Good luck hunting
Henrik
henrik is offline   Reply With Quote
Old   July 6, 2009, 13:07
Steve Hansel
Thanks for the reply. I actually found my problem, but I will keep this information for the next one that comes up.
Steve
Old   July 31, 2010, 13:13
Default turbDyMFoam segmentation fault
Aldo Iannetti
aldo.iannetti is on a distinguished road
[QUOTE=hansel;221636]Thanks for the reply. I actually found my problem, but I will keep this information for the next one that comes up.
can you please explane me problems about turbDyMFoam you had? I Think I have the same problem. Can you please give me some advice in order to set up ggi in turbDyMFoam cases?
Thanks
Aldo
aldo.iannetti is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Segmentation fault when starting paraFoam gaffu OpenFOAM Installation 16 November 18, 2011 19:05
segmentation fault usker Siemens 5 March 5, 2007 23:14
KIVA and Segmentation Fault Felix Main CFD Forum 2 January 18, 2006 01:24
Fluent parallel: segmentation fault? hp FLUENT 2 September 6, 2001 14:18
