August 7, 2009, 01:04 |
Compile problem ccm26ToFoam in OpenFoam-1.6
Stefan Hildenbrand
Rep Power: 16 |
Dear all,
I was trying to compile ccm26ToFoam with the new OpenFOAM Version 1.6. Besides having to copy some Headerfiles and other stuff from Version 1.5, I get a problem as follows: ccm26ToFoam.C: In function ‘int main(int, char**)’: ccm26ToFoam.C:915: error: no matching function for call to ‘Foam::fvMesh::fvMesh(Foam::IOobject, Foam:ointField&, Foam::faceList&, Foam::labelList&, Foam::labelList&)’ /soft/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:192: note: candidates are: Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<Foam::cell> >&, bool) /soft/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:181: note: Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<int> >&, const Foam::Xfer<Foam::List<int> >&, bool) /soft/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:169: note: Foam::fvMesh::fvMesh(const Foam::IOobject&) /soft/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:148: note: Foam::fvMesh::fvMesh(const Foam::fvMesh&) I guess that there is some change in the syntax of the funtion call - but is that all? Do I have to change other parts of the source code as well? Thanks for you help, Stefan |
August 7, 2009, 04:23 |
Mattijs Janssens
Rep Power: 26 |
No, the only change is in the constructor of fvMesh. I pushed a fixed ccm26ToFoam.C to 1.6.x.
I got a clean build by cd ThirdParty-1.6 ./AllwmakeLibccmio wmake $FOAM_UTILITIES/mesh/conversion/Optional/ccm26ToFoam/ thanks for reporting. |
August 7, 2009, 04:50 |
Stefan Hildenbrand
Rep Power: 16 |
Hi Mattijs,
thanks a lot. That solved the problem. Stefan |
August 7, 2009, 08:36 |
Where i can find this new ccm26tofoam.c file?
Rep Power: 16 |
i read your discussion and have the same problem. mattijs said, he solved the problem with a new ccm26ToFoam.C file. Here's my question: Where i can find this file? Or is there another way to change only the ccm26ToFoam.C file? Thank you in advance. |
August 7, 2009, 08:48 |
Mattijs Janssens
Rep Power: 26 |
You can get 1.6.x from the git repository (see http://www.opencfd.co.uk/openfoam/download.html)
August 7, 2009, 08:59 |
Thanks a lot
Rep Power: 16 |
Thanks. I have to install git firstly.
August 19, 2009, 03:57 |
Markus Bentele
Hello Mattijs,
I see the same errors as Stefan, tried to solve it as you posted but got no changes. Are there any further suggestions ? Thanks a lot Markus ################ ben_fnx520> cat libccmio-2.6.1/Make/files /* Note: make any changes to this file in wmakeFiles/ */ adf = libadf $(adf)/ADF_fortran_2_c.c $(adf)/ADF_interface.c $(adf)/ADF_internals.c ccmio = libccmio $(ccmio)/ccmio.c $(ccmio)/ccmiocore.c $(ccmio)/ccmioprivate.c $(ccmio)/ccmioutility.c $(ccmio)/ccmioversion.c /* * the cgns library is not used by ccmio * retain for documentation purposes only * cgns = libcgns $(cgns)/adf_cond.c $(cgns)/adf_ftoc.c $(cgns)/cgns_error.c $(cgns)/cgns_internals.c $(cgns)/cgnslib.c */ LIB = $(FOAM_LIBBIN)/libccmio ben_fnx520> cat libccmio-2.6.1/Make/options /* Note: make any changes to this file in wmakeFiles/ */ /* EXE_INC = */ ben_fnx520> ./AllwmakeLibccmio + packageDir=libccmio-2.6.1 + '[' '!' -d libccmio-2.6.1 ']' + '[' -d libccmio-2.6.1 -a '!' -d libccmio-2.6.1/Make ']' + '[' -d libccmio-2.6.1/Make ']' + wmake libso libccmio-2.6.1 '/disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/lib/linux64GccDPOpt/libccmio.so' is up to date. wmake $FOAM_UTILITIES/mesh/conversion/Optional/ccm26ToFoam SOURCE=ccm26ToFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/meshTools/lnInclude -I/disk_f231/tmp/REDHAT/OpenFoam_16/ThirdParty-1.6/libccmio-2.6.1 -I/disk_f231/tmp/REDHAT/OpenFoam_16/ThirdParty-1.6/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ccm26ToFoam.o ccm26ToFoam.C: In function \u2018int main(int, char**)\u2019: ccm26ToFoam.C:915: error: no matching function for call to \u2018Foam::fvMesh::fvMesh(Foam::IOobject, Foam:ointField&, Foam::faceList&, Foam::labelList&, Foam::labelList&)\u2019 /disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:192: note: candidates are: Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<Foam::cell> >&, bool) /disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:181: note: Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<int> >&, const Foam::Xfer<Foam::List<int> >&, bool) /disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:169: note: Foam::fvMesh::fvMesh(const Foam::IOobject&) /disk_f231/tmp/REDHAT/OpenFoam_16/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvMesh.H:148: note: Foam::fvMesh::fvMesh(const Foam::fvMesh&) make: *** [Make/linux64GccDPOpt/ccm26ToFoam.o] Error 1 |
August 19, 2009, 06:56 |
Mattijs Janssens
Rep Power: 26 |
You seem to be running 1.6. As said the fix is in 1.6.x.
August 19, 2009, 09:54 |
#9 |
Markus Bentele
Yep
thank you Markus |
October 7, 2009, 08:14 |
wmakeFiles/libccmio/Make not found
#10 |
Niclas Wiker
Hello all,
I just started using OF and I have some problems when trying to compile ccm26ToFoam. I get an error from AllwmakeLibccmio telling me that it cannot copy the folder wmakeFiles/libccmio/Make into the libccmio-2.6.1 folder. When looking inside the ThirdParty-1.6.x folder (I'm running the Git version of OF which compiled just fine on my 64bit linux box) there is no wmakeFiles folder anywhere to find. Shouldn't it be one there or should I be looking somewhere else? I have also downloaded and unpacked the 32bit ThirdParty files from the OF download site but can't find a wmakeFiles folder there either... All suggestions on how to solve my problem are much appreciated. Best regards Niclas |
October 17, 2009, 05:42 |
The missing Make files...
#11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hello Niclas,
Well, I ran into the same problem and it seems it's a remnant bug from a year ago... the fix is here. Fortunately it seems to still work! But don't forget to use the git version (1.6.x) for ccm26ToFoam to build properly Best regards, Bruno |
October 20, 2009, 15:43 |
#12 |
Niclas Wiker
It worked! Many thanks Bruno!
Cheers Niclas |
ccm26tofoam, compile problems, openfoam 1.6 |
OpenFoam 1.6 Permissions in Ubuntu 9.04 | AlanR | OpenFOAM Installation | 14 | December 28, 2009 19:45 |
problems with installing OpenFOAM 1.6 | su_junwei | OpenFOAM Installation | 8 | September 10, 2009 12:54 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
fortran compile problem | Don | CFX | 1 | November 5, 2008 05:33 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
