July 1, 2011, 04:05 |
[solved] decomposePar memory corruption
Lorenzo A. Ricciardi
Rep Power: 15 |
Hi Foamers,
this is my first post, and I'm also rather new to OpenFoam as well. I've implemented an actuator disk solver as in http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/erikSvenning/erikSvenningReport.pdf I had to change some minor things, for that tutorial was written for OF 1.5 dev and I've OF 1.71 and OF 2... however, it compiled fine and also seems to work fine on single processor (still have to test the results, though) The problem is: if I try to run decomposePar, i get a memory corruption message, which never occurred before... Any ideas about what to check? checkMesh gives no errors, and it's a simple "box" geometry with 512k cells created with blockMesh Since it works correctly with other solvers, is there any chance that the error somehow comes from the new solver? Thanks Last edited by lichmaster; July 4, 2011 at 05:31. Reason: solved |
July 4, 2011, 05:30 |
Rep Power: 15 |
I've managed to solve this problem...
I didn't correctly set the I.C of VolumeForce: the object entry was still "U" instead of "VolumeForce". However, I find it very strange that no "canonical" error messages are given for this kind of mistakes, and also that single processor simulations have no problems at all... |
decomposepar, memory corruption |
Fluent Parallel Memory Usage | David Christopher | FLUENT | 1 | March 3, 2011 02:20 |
How to optimize the memory usage when using FEM | vasilis | Main CFD Forum | 11 | August 24, 2009 23:57 |
Memory error? | Young | CFX | 3 | September 30, 2008 11:33 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 17:50 |
Run-Time memory conifguration Error | Graeme | CFX | 1 | February 20, 2006 23:04 |
