Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[stressAnalysis] Thermal stress of a beam
Old   December 31, 2013, 13:44
Default Thermal stress of a beam
Alessandro
ale.barba is on a distinguished road
I'd like to calculate the stress applied on a beam due to the temperature increasing.
The beam is 1m long and diametere is 0.1m. The displacement is neglacted all over the surface of the beam.
The problem seems simple, but solver doesn't find a solution.
Any suggestion?
Attached are the input files (except for the mesh).
ale.barba is offline   Reply With Quote
Old   January 1, 2014, 16:05
Alessandro
Does anyone say me if there is something wrong in the fvSolution file?
solvers
    "(D|T)"
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.9;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 20;
        agglomerator    faceAreaPair;
        mergeLevels     1;
stressAnalysis
    compactNormalStress no;
    thermalStress yes;
    nCorrectors 100000;
    D 1e-06;
    T 1e-06;
or fvSchemes?
d2dt2Schemes
    default         steadyState;
ddtSchemes
    default         Euler;
gradSchemes
    default         leastSquares;
    grad(D)         leastSquares;
    grad(T)         leastSquares;
divSchemes
    default         none;
    div(sigmaD)     Gauss linear;
laplacianSchemes
    default         none;
    laplacian(DD,D) Gauss linear corrected;
    laplacian(DT,T) Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         none;
fluxRequired
    default         no;
    D               yes;
    T               no;
Thermal Stress - Modelling of an interactive coupled Simulation macRC Structural Mechanics 0 January 10, 2019 05:14
thermal stress analysis with fluid? sheaker FLUENT 0 April 20, 2018 16:32
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 16:03
Stress analysis of a clamped beam cvasse OpenFOAM Running, Solving & CFD 0 April 24, 2017 07:44
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
