[solids4Foam] Debian 12 and GCC 12 and OpenFOAM 2306 installation |
August 13, 2023, 07:24 |
Jan Groenewald
Rep Power: 2 |
I get the attached errors when compiling on Debian 12 with the default gcc 12.2.0 and OpenFOAM 2306.
physicsModel/physicsModel.C: In static member function ‘static Foam::autoPtr<Foam::physicsModel> Foam::physicsModel::New(Foam::Time&, const Foam::word&)’: physicsModel/physicsModel.C:115:5: error: ‘physicsModelConstructorTable’ is not a class, namespace, or enumeration 115 | physicsModelConstructorTable::iterator cstrIter = | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ physicsModel/physicsModel.C:118:9: error: ‘cstrIter’ was not declared in this scope; did you mean ‘strstr’? 118 | if (cstrIter == physicsModelConstructorTablePtr_->end()) | ^~~~~~~~ | strstr physicsModel/physicsModel.C:130:34: error: ‘cstrIter’ was not declared in this scope; did you mean ‘strstr’? 130 | return autoPtr<physicsModel>(cstrIter()(runTime, region)); | ^~~~~~~~ | strstr make: *** [/home/jan/0_no_backup_overwrite/OpenFOAM-v2306/wmake/rules/General/transform:38: Make/linux64GccDPInt32Opt/physicsModel/physicsModel.o] Error 1 |
August 16, 2023, 13:24 |
Jan Groenewald
Rep Power: 2 |
Fixed in Debian 12 and GCC 12
August 18, 2023, 12:31 |
Philip Cardiff
Rep Power: 34 |
