[swak4Foam] installation problem: "./Allwmake: ... [[: not found"
Old   May 25, 2012, 11:11
Default installation problem: "./Allwmake: ... [[: not found"
Rajarshi Bhattacharjee
Rajarshi is on a distinguished road
I'm very new to cfd programming and openfoam. I need groovyBC to impose a robin boundary condition of the type (dT/dn)_wall=(h/k)(T_wall-T_inf) at the walls(according to http://www.cfd-online.com/Forums/ope...acianfoam.html) and hence require swak4Foam. I've downloaded swak4Foam to $HOME/swak4Foam directory and used 'wmake all' to build. But it seems it hasn't installed correctly as it cannot identify "libgroovyBC.so" in controlDict file of the case after running blockMesh.
This is the output after running 'wmake all' (for the 2nd time):
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
./Allwmake: 9: [[: not found
./Allwmake: 17: [[: not found
Bison is version 2.4.1
./Allwmake: 33: cannot open 2.3: No such file
./Allwmake: 33: [[: not found
OpenFOAM-version: Major 2 Minor 1 Patch 0
./Allwmake: 67: [[: not found
No change to swak4FoamParsers/foamVersion4swak.H
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libgroovyBC.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libswakFunctionObjects.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libswakTopoSources.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libswakSourceFields.so' is up to date.
'/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration
make[1]: Entering directory `/home/rajarshi/swak4Foam/Utilities/funkyDoCalc'
make[1]: `/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: Leaving directory `/home/rajarshi/swak4Foam/Utilities/funkyDoCalc'
make[1]: Entering directory `/home/rajarshi/swak4Foam/Utilities/funkySetBoundaryField'
make[1]: `/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/bin/funkySetBoundaryField' is up to date.
make[1]: Leaving directory `/home/rajarshi/swak4Foam/Utilities/funkySetBoundaryField'
make[1]: Entering directory `/home/rajarshi/swak4Foam/Utilities/funkySetFields'
make[1]: `/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/bin/funkySetFields' is up to date.
make[1]: Leaving directory `/home/rajarshi/swak4Foam/Utilities/funkySetFields'
make[1]: Entering directory `/home/rajarshi/swak4Foam/Utilities/replayTransientBC'
make[1]: `/home/rajarshi/OpenFOAM/rajarshi-2.1.0/platforms/linuxGccDPOpt/bin/replayTransientBC' is up to date.
make[1]: Leaving directory `/home/rajarshi/swak4Foam/Utilities/replayTransientBC'
Why does it show these "not found" at the beginning( also, I don't have python installed)? Please help me identify the problem. Any advice is appreciated.
Thank you.
Rajarshi is offline   Reply With Quote
Old   May 25, 2012, 17:33
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by Rajarshi View Post
Thank you.
You're working on a fairly recent Ubuntü-Linux, right? They seem to have replaced the default shell /bin/sh : don't know what it is, but not a bash anymore. Replace in Libraries/Allwmake the first line
#! /bin/sh
with
#! /bin/bash
and it should work.
The warning in the beginning is about a configuration file. If you don't want the library with the Python-support, then you're fine
gschaider is offline   Reply With Quote
Old   May 26, 2012, 01:31
Thank you Bernhard!!! Yes, I am using ubuntu 11.10. I made the changes and its working fine right now.
Old   May 30, 2012, 18:03
slint is on a distinguished road
I tried to install swak4foam on Ubuntu 12.04 LTS. After downloading swak4Foam to $HOME/swak4Foam directory and using ./Allwmake , i got this error message while starting simpleFoam:
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1175
dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
could not load "libgroovyBC.so"
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
Unknown patchField type groovyBC for patch type patch
Valid patchField types are :
62
SRFFreestreamVelocity
SRFVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
fixedGradient
fixedInternalValue
fixedNormalSlip
fixedShearStress
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
nonuniformTransformCyclic
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentInlet
uniformFixedValue
waveTransmissive
wedge
zeroGradient
file: /home/robert/OpenFOAM/robert-2.1.0/run/cube3d/cube3d_kepsilon/0/U::boundaryField::inlet from line 25 to line 28.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135.
FOAM exiting
I got multiple error messages while compiling:
./Allwmake: 6: ./Allwmake: [[: not found
./Allwmake: 14: ./Allwmake: [[: not found
./Allwmake: 1: ./Allwmake: bison: not found
Bison is version
./Allwmake: 23: ./Allwmake: cannot open 2.3: No such file
./Allwmake: 23: ./Allwmake: [[: not found
./Allwmake: 56: ./Allwmake: [[: not found
SOURCE=FieldValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/FieldValueExpressionParser.C Make/linux64GccDPOpt/FieldValueExpressionParser.tab.hh; mkdir $$; cd $$; bison -ra -v -d ../$SOURCE ; mv *.tab.cc ../Make/linux64GccDPOpt/FieldValueExpressionParser.C ; sed -i.bak "s/position.hh/FieldValueExpressionParser_position.hh/" location.hh ; mv location.hh ../lnInclude/FieldValueExpressionParser_location.hh ; mv stack.hh ../lnInclude/FieldValueExpressionParser_stack.hh ; mv position.hh ../lnInclude/FieldValueExpressionParser_position.hh ; sed -i.bak "s/stack.hh/FieldValueExpressionParser_stack.hh/;s/location.hh/FieldValueExpressionParser_location.hh/" FieldValueExpressionParser.tab.hh ;mv *.hh ../lnInclude ; touch -r ../$SOURCE ../lnInclude/FieldValueExpressionParser*.hh ; cd ..; rm -r $$; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam210/src/finiteVolume/lnInclude -I/opt/openfoam210/src/sampling/lnInclude -I/opt/openfoam210/src/triSurface/lnInclude -I/opt/openfoam210/src/lagrangian/basic/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/FieldValueExpressionParser.C -o Make/linux64GccDPOpt/FieldValueExpressionParser.o
/bin/sh: 1: bison: not found
So I guess the installation failed. The advice from gschaider don't work.
Can anybody help me to identify the problem?
Thanks
slint is offline   Reply With Quote
Old   May 30, 2012, 18:18
Assistant Moderator
Bernhard Gschaider
What could this mean? Maybe that a prerequisite is missing?
Old   June 2, 2012, 12:49
Indeed, bison was not installed. I thought, this is a standard application in ubuntu.
Thanks
Old   May 13, 2013, 05:20
Default compiler option
nik
nicolas
nik is on a distinguished road
I am trying to install swak4Foam and I have one question. Is it possible to define which compiler to use? On the machine I am trying to install, there is a problem with the compiler name, and when I am trying to compile I have to explicitly define CC=icc. I have the same problem with OpenFOAM, and the way around is when I am trying to compile an application, I just go to Make/options and add CC=icc.
This is what I get when I try to install swak4Foam.
SOURCE=helpers/printSwakVersion.C ;   -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572   -DNoRepository -IMake/linux64IccDPOpt  	 -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/sampling/lnInclude  -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/triSurface/lnInclude -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/surfMesh/lnInclude -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/lagrangian/basic/lnInclude -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/meshTools/lnInclude -IlnInclude -I. -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/gpfs/eb/software/OpenFOAM/2.1.1-ictce-4.0.6/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOpt/printSwakVersion.o
/bin/sh: -Dlinux64: command not found
Most probably CC is empty and when expanding it leaves it blank.
Is there something I can do here?
Regards,
Nicolas
nik is offline   Reply With Quote
Old   May 13, 2013, 07:25
Assistant Moderator
Bernhard Gschaider
Regards,
Nicolas
At first: for the sake of your sanity I'd recommend always using the same compiler to compile swak as the one that compiled OF
Compiler and options are determined by the appropriate sub-directory in wmake/rules whose name is taken from the environment variables WM_ARCH, WM_ARCH_OPTION and WM_COMPILER. To override any of these either edit etc/bashrc or set them in a files ~/OpenFOAM/site/2.2.x/prefs.sh. Something like
export WM_COMPILER=Icc
should use the ready-made settings for the Intel-compiler
With some architectures the compiler can be overruled by setting WM_CC and WM_CXX but only do this if you know what you're doing (see first sentence)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 13, 2013, 08:05
nik
nicolas
Dear Bernhard,
thank you very much for your reply. The problem was with the environmental variables set for the compiler options of OpenFOAM in wmake/rules. Now swak4Foam is installing. Thanks again.
Regards,
Nicolas
swak4foam error
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 18:45
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 16:16
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
