[swak4Foam] interFoam groovyBC from other data
Old   May 16, 2013, 00:57
Default interFoam groovyBC from other data
haze_1986 is on a distinguished road
Hi all, I am starting out on a near-field free surface simulation using data from another depth averaged data. I wanted to test out interFoam first with groovyBC feeding in surface elevation and velocities from all 4 boundaries NESW.
I have successfully ran modifying from damBreak and groovyWaveTank and it works fine when there is only one BC from the left and the rest are either empty or zeroGradient. I have tried for both linear Airy and 2nd order Stokes wave with deep water assumptions for the velocities.
When I tried to use groovyBC for both left and right, interFoam crashes, sometimes immediately and sometimes after quite a number of time steps. Am I missing out something here? Please advise, thanks.
haze_1986 is offline   Reply With Quote
Old   May 16, 2013, 05:37
Assistant Moderator
Bernhard Gschaider
I think the problem is not groovyBC but the physics you're trying to impose. For instance setting Dirichlet-conditions on all four boundaries is almost never a good idea as it is bound to violate mass conservation (even if the data you use is "good": numerical inaccuracies are inevitable and will add up)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 16, 2013, 08:02
While I fully agree on your point, I've narrowed down the issue to setting the inlet to the right hand side. It does not seem to work the way as the left hand inlet, thus causing the crash. I used the same boundary condition except adding a negative sign in front of u-velocity. The left hand BC has been changed to zeroGradient. Am I doing something wrong?
problem with exporting data to Tecplot v.jab OpenFOAM Post-Processing 2 January 11, 2017 08:56
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 02:47
[OpenFOAM] saving data in paraview aylalisa ParaView 3 May 31, 2014 11:38
[General] Warping Cells by Vectors? ronwelty ParaView 10 April 29, 2014 05:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
