[swak4Foam] Temperature Average on internal faceZone with swak4Foam
Old   October 26, 2013, 22:27
Default Temperature Average on internal faceZone with swak4Foam
woodwick's Avatar
Alessandro
woodwick is on a distinguished road
I was trying to get the average temperature over a faceZone. I installed swak4Foam and add the following lines in controlDict:
    T_averaged_CORE
        type swakExpression;
        variables "T";
        valueType faceZone;
        zoneName CORE;
        accumulations (
            average
        expression "average(T)";
        verbose true;
but I get the following error:
--> FOAM FATAL ERROR:
Context: "- From dictionary: . T_averaged_CORE"
No terminating ';' found in expression '"T"'
Where am I doing wrong?
woodwick is offline   Reply With Quote
Old   October 26, 2013, 22:48
woodwick's Avatar
Alessandro
I solved the problem by using a similar sintax in the mass flow example
http://openfoamwiki.net/index.php/Co...e_calcMassFlow
    T_averaged_CORE
        enabled         true;
        autoInterpolate true;
        // I introduced the previous instruction in order to avoid the error : Could not find a field name T of type scalar (neither surfaceScalarField nor volScalarField) autoInterpolate
        outputControl   timeStep;
        outputInterval  1;
        //variables "T";
        valueType faceZone;
        zoneName CORE;
        expression "T";
        accumulations (
            average
        verbose true;
Old   October 28, 2013, 18:20
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
    T_averaged_CORE
        enabled         true;
        outputInterval  1;
        //variables "T";
        valueType faceZone;
        zoneName CORE;
        expression "T";
        accumulations (
            average
        verbose true;
OK. But you are aware that this is "only" the arithmetic average? That it only gives the "physically correct" value if all faces are of the same size. Otherwise I'd recommend the weightedAverage-accumulation (if your swak-version already has it) or implementing a area-weighted averaging in swak-terms (there are plenty examples for that)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
[swak4Foam] time average sample set with swak4Foam cnsidero OpenFOAM Community Contributions 3 July 30, 2018 10:06
Anys Average temperature apo FLUENT 2 November 4, 2014 12:31
time derivative of average temperature will_ca OpenFOAM Post-Processing 0 September 10, 2014 11:49
mass weighted average temperature along a curve preetam69 FLUENT 1 July 5, 2013 02:48
[swak4Foam] Mass flow through faceZone using swak4foam when running in parallel billie OpenFOAM Community Contributions 22 May 14, 2013 07:20
