[swak4Foam] Power law inlet velocity using groovyBC
Old   November 11, 2013, 22:34
Default Power law inlet velocity using groovyBC
NF
aviator is on a distinguished road
I am using OpenFOAM 2.2.1 and have installed swak4Foam 0.2.4
I need to use a power law as an inlet velocity, and the outlet wind profile is set same as the inlet wind profile.
This is my 0/U
|  \\    /   O peration     | Version:  2.2.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (6.751 0 0);
boundaryField
    upper
        type            fixedValue;
        value           uniform (6.751 0 0);
    front
      type    groovyBC;
      value   uniform (0 0 0);
      variables (
    "Umet=6.751;"
    "height=pos().y;"
    "quo=height/60;"
       valueExpression
             "-Umet*pow(quo,0.2)*normal()";
    back
      type    groovyBC;
      variables (
    "Umet=6.751;"
    "height=pos().y;"
    "quo=height/60;"
       valueExpression
    square
        type            fixedValue;
    floor
        type            fixedValue;
    right
        type            symmetryPlane;
    left
        type            symmetryPlane;
But I got the following error.
swak4Foam: Allocating new repository for sampledGlobalVariables
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::pow(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  parserPatch::PatchValueExpressionParser::parse() in "/home/openfoam/OpenFOAM/openfoam-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#7  Foam::PatchValueExpressionDriver::parseInternal(int) in "/home/openfoam/OpenFOAM/openfoam-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#8  Foam::CommonValueExpressionDriver::parse(std::string const&, Foam::word const&) in "/home/openfoam/OpenFOAM/openfoam-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#9  Foam::groovyBCFvPatchField<Foam::Vector<double> >::updateCoeffs() in "/home/openfoam/OpenFOAM/openfoam-2.2.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so"
#10   at gaussLaplacianSchemes.C:0
#11  Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#12  Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#13  Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#14  Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#15  Foam::incompressible::RASModels::kOmegaSST::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#16
 in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/pisoFoam"
#17  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#18
Floating point exception (core dumped)
Can someone please clarify this. I am fairly new to OpenFOAM and would appreciate your help. Thank you.
aviator is offline   Reply With Quote
Old   November 12, 2013, 09:53
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
First, do you have negative coordinate in y direction eg. pos().y < 0? If not, then try Foam:ow instead of pow only.
duongquaphim is offline   Reply With Quote
Old   November 12, 2013, 21:02
NF
Thank you for pointing that out.
After reading your comment, I think that I made a mistake. I should've use the z-coordinate, which is the height, since the inlet velocity varies at different height. My z-coordinate is always positive. Then I changed the code into something like this.
    front
      type    groovyBC;
      variables "Umet=6.751;height=pos().z;";
      valueExpression "Umet*pow((height/60),0.2)*normal()";
And it's running.
I did this assuming that pos().z would give me a vector of z-coordinate though. And by assuming that multiplying the equation with normal() would give me the velocity in the x-direction. Please let me know if this is not correct.
Thank you.
Old   November 13, 2013, 10:50
Duong A. Hoang
I think that's correct assuming your normal() is (1,0,0). What you can do to check is to visualize the velocity profile at the inlet at the next saved time step in paraview.
Cheers.
groovybc
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
