[swak4Foam] compiling swak4foam on an IBM Dataplex running 64-bit RedHat 6.3
Like Tree1Likes
Old   December 18, 2013, 14:35
Default compiling swak4foam on an IBM Dataplex running 64-bit RedHat 6.3
jianni is on a distinguished road
I am having trouble trying to compile swak4foam for Openfoam 2.1.1 (please see below). I have Openfoam 2.1.1 running in parallel using openmpi with gcc4.4. Now I need to get swak4foam to compile. Any suggestions?
60 pershing-login04> ./Allwmake
Reading variables from 'swakConfiguration'
Checking swak4Foam-version and generating file
Swak version is 0.2.4
Bison is version 2.4.1
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 1 Patch 1 (-1 == x)
swak4FoamParsers/foamVersion4swak.H changed
wmakeLnInclude: linking include files to ./lnInclude
make: *** No rule to make target `/usr/cta/unsupported/swak/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/debugName.H', needed by `plugins/SampledSurfaceValuePluginFunction.dep'.  Stop.
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
jianni is offline   Reply With Quote
Old   December 25, 2013, 08:08
Retired Super Moderator
Bruno Santos
Greetings jianni and welcome to the forum!
Can you please specify how exactly you've installed OpenFOAM 2.1.1 and on which system (Linux or Mac OS X)?
I ask this because something is not right in the feedback that swak4Foam's Allwmake is giving us, namely this address:
It's not pointing to any of the standard OpenFOAM installation paths, which seems to imply that something very wrong is going on
And when if you run the following commands, right after you run Allwmake, what do they give you?
icoFoam -help
which icoFoam
Best regards,
Bruno
Old   December 26, 2013, 09:18
Dear Bruno,
Thanks for the response! I'm trying to compile this on an IBM Dataplex running 64-bit RedHat 6.3:
"Red Hat Enterprise Linux Server release 6.3 (Santiago)"
For icoFoam:
60 pershing-login04> icoFoam -help
Usage: icoFoam [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-noFunctionObjects
do not execute functionObjects
-parallel run in parallel
-roots <(dir1 .. dirN)>
slave root directories for distributed running
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.1.1 (see www.OpenFOAM.org)
Build: 2.1.1-221db2718bbb
61 pershing-login04> which icoFoam
/usr/cta/unsupported/swak/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/icoFoam
62 pershing-login04> uname -a
Linux pershing-login04 2.6.32-279.33.1.el6.x86_64 #1 SMP Sun Jun 30 03:00:43 EDT
2013 x86_64 x86_64 x86_64 GNU/Linux
Also, I noticed the include file debugName.H is nowhere in the entire directory structure! Could I been using a version of swak for Openfoam 1.x by accident?
-James
Old   December 26, 2013, 10:43
Bruno Santos
Greetings James,
The problem seems to be that you have a binaries-only installation of OpenFOAM 2.1.1. And since you need to build swak4Foam from source, you need the source code of OpenFOAM as well.
Check the contents of this folder:
If it's empty or it doesn't even exist, then that is the reason why swak4Foam is not able to build.
Do you know how exactly OpenFOAM 2.1.1 was installed on the IBM Dataplex you are using?
Best regards,
Bruno
Old   December 26, 2013, 10:49
I've installed Openfoam (2.x and 1.x) on this (and many other systems) here.
All the source files are there:
74 pershing-login04> find src | wc -l
17120
75 pershing-login04> find src -name "*.H" -print | wc -l
5274
76 pershing-login04> ls -ltrR src | grep -i debug | grep -i name
-James
Old   December 26, 2013, 13:45
Bruno Santos
Hi James,
OK, I did some researching and tests:
  1. It's not swak4Foam 1.x, because you should have gotten this message:
    lnInclude/swak.H:58:2: error: #error "This swak4Foam-version is only used for the 1.x-versions of OpenFOAM. For higher versions there is a special branch"
  2. The file "debugName.H" came into existence with OpenFOAM 2.2.x.
So, my guess is that you either have a strange shell environment going on, or you didn't run Allwclean after building swak4Foam for OpenFOAM 2.2.2.
Best regards,
Bruno
Old   December 26, 2013, 14:34
./Allwclean corrected the issue!
Now I need to find out how to pass PYTHONINCLUDE to swak build (it cannot find Python.h):
142 pershing-login04> ./Allwmake | tee view.txt
No change to swak4FoamParsers/foamVersion4swak.H
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
SOURCE=pythonInterpreterWrapper.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/usr/cta/CSE.20130926/Release/python-2.7.5/include -I../swak4FoamParsers/lnInclude -I../simpleFunctionObjects/lnInclude -IlnInclude -I. -I/usr/cta/unsupported/swak/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/usr/cta/unsupported/swak/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pythonInterpreterWrapper.o
In file included from pythonInterpreterWrapper.C:37:
pythonInterpreterWrapper.H:52:20: error: Python.h: No such file or directory
pythonInterpreterWrapper.H:79: error: ISO C++ forbids declaration of âPyThreadStateâ with no type
pythonInterpreterWrapper.H:79: error: expected â;â before â*â token
Old   December 26, 2013, 14:45
Never mind. They changed the Python paths on me. I'm now getting this error:
178 pershing-login04> ./Allwmake | tee view.txt
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakPythonIntegration.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
'/usr/people/ianni/OpenFOAM/ianni-2.1.1/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
Compiling user function-plugin ../Examples/UserPlugins/swakTestFunctionPlugins
wmake error: file 'Make/files' does not exist in /usr/cta/unsupported/swak/OpenFOAM-2.1.1/swak4Foam/Examples/UserPlugins/swakTestFunctionPlugins
Old   December 26, 2013, 14:49
Bruno Santos
Hi James,
  1. Looks like the file "Examples/UserPlugins/swakTestFunctionPlugins/Make/files" is missing. Perhaps you erased it by accident?
  2. Uhm... could you please use the [CODE] markers to post code and output? It's explained on the last link of my signature.
Best regards,
Bruno
Old   December 26, 2013, 14:53
The path is there, but there are no files. I cannot imagine accidentally erase such files in such a long path. Maybe they were never there?
187 pershing-login04> pwd
/mnt/gpfs_cta/unsupported/swak/OpenFOAM-2.1.1/swak4Foam/Examples/UserPlugins/swakTestFunctionPlugins/Make
188 pershing-login04> ls -ltr
total 0
Old   December 26, 2013, 15:00
Bruno Santos
Yes, yes there are files in that folder:
Old   December 26, 2013, 15:11
I checked the zip file given to me and those files are NOT there. I think the person who gave me the swak zip file may have inadvertently not included them. I really, REALLY wish you guys would create a gzipped tar file to download instead of utilizing SVN as all SVN ports are blocked.
-James
Old   December 26, 2013, 15:17
Bruno Santos
Hi James,
Well, you can always report this on the bug tracker -> http://openfoamwiki.net/index.php/Co...oam#Bugreports
But still, if you look at the wiki page, section Downloading: http://openfoamwiki.net/index.php/Co...am#Downloading - you'll see that nowadays there are several ways to download the files.
In addition, from my Github repository, which unofficially provides a git based mirror and tweaks of the official SVN swak4Foam (for OpenFOAM 2.x), you can even download zip files directly: https://github.com/wyldckat/swak4foam/tree/OF22X
Best regards,
Bruno
Old   December 27, 2013, 10:45
Bruno,
I noticed that SWAK placed the shared libraries in my home directory. Can I simply copy these to a common area for anyone to link to? I'm assuming there are no hard coded paths inside these shared libraries?
-James
Old   December 27, 2013, 11:52
Bruno Santos
Hi James,
AFAIK, the paths should not be hard-coded into the binaries of swak4Foam. If they are, then it's a bug
OpenFOAM has got a path meant for sharing custom solvers et al with more than one person... ah, I've found the post that explains this: http://www.cfd-online.com/Forums/ope...tml#post241758 post #4
Best regards,
Bruno
Old   December 30, 2013, 14:41
Bruno,
Your git repository also does NOT have the Examples/UserPlugins/* area, the SVN repository is blocked and I cannot create tar images from SourceForce. Any other suggestions where I can get the full swak version for Openfoam 2.x ?
-James
Old   December 30, 2013, 15:00
Bruno Santos
Hi James,
That's very, very strange. Did you download this file: https://github.com/wyldckat/swak4foam/archive/OF22X.zip - or did you use "git clone"?
There are two unofficial mirror repositories of swak4Foam at GitHub, which rely on git-svn to keep track of the history from SVN in Git form:
Both pages have the big ZIP button on the right of the page, but the ZIP links are also provided in the list above. Both of those repositories only have the master branch, so there is no confusion with the branches.
Please let me know if these work or not!
Best regards,
Bruno
Old   December 31, 2013, 09:52
Is this correct for linux-64 bit, openfoam 2.x ?
openfoam-extend-Breeder2.0-libraries-swak4Foam-master.zip
Old   December 31, 2013, 11:26
Bruno Santos
Yes, it's the source code of swak4Foam for OpenFOAM 2.x.
32 or 64 bit is not applicable in this case, since it's the source code and you can compile it for any architecture
Old   December 31, 2013, 14:27
That worked! Full compilation and no errors! Thanks!
A quick question : I dont see the binary funkySetFields. Is that supposed to be a stand alone executable or something to be linked with? .
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
Compiling and Running UDFs on an IBM Power3 S. Hollman FLUENT 0 January 6, 2005 11:23
