[swak4Foam] problems using "accumulations (weightedAverage)" in parallel
Old   January 8, 2014, 04:57
Default problems using "accumulations (weightedAverage)" in parallel
Sam Fredriksson
safre is on a distinguished road
I have started to use swak4foam which seems to be a very interesting and powerful tool. I have though some problems as below.
I would like to use swak4foam to monitor RMS and mean for U and T during runtime. I have managed to do that in serial but get into trouble when doing it in parallel.
As an example in my controlDict:
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
functions
TMean
type swakExpression;
valueType surface;
surfaceName monitoringSurface1;
surface {
type plane;
basePoint (0 0 0.1023);
normalVector (0 0 1);
interpolate false;
functionObjectLibs ("libsampling.so");
outputControlMode timestep;
outputInterval 1;
zoneName monitoringZone1;
accumulations (weightedAverage);
expression "T";
verbose true;
[1] --> FOAM FATAL ERROR:
[1] Can not construct weight field of the expected size. For sizes on the processors see above
[1]
[1]
[1] From function SampledSurfaceValueExpressionDriver::weightsNonPoi nt
[1] in file SampledSurfaceValueExpressionDriver.C at line 316.
Is this a general problem or something I have done wrong in my setup of the case?
I then tried to use the "sum" function which would work (although not ideal) in this specific situation since all my cells are of the same size. It worked in parallel but then I get the twize the actual result - is this expected?
libs (
"libOpenFOAM.so"
functions
TSum
valueType surface;
surface {
type plane;
interpolate false;
outputInterval 1;
accumulations (sum);
expression "T";
verbose true;
Regards, Sam
safre is offline   Reply With Quote
Old   January 8, 2014, 08:36
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
libs (
"libOpenFOAM.so"
functions
TMean
valueType surface;
surface {
type plane;
interpolate false;
outputInterval 1;
expression "T";
verbose true;
[1]
[1]
libs (
"libOpenFOAM.so"
functions
TSum
valueType surface;
surface {
type plane;
interpolate false;
outputInterval 1;
expression "T";
verbose true;
Regards, Sam
Which version of swak are you using? Latest released on or the development version from the repository. I vaguely remember fixing something with the weight-function. But not necessarily this problem
No. 2times the actual result shouldn't happen. You've got 2 CPUs and get EXACTLY 2 times the result (äh. Have you tried 3 CPUs?)
In both cases I'd be interested in simple example cases to reproduce the problem
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   January 8, 2014, 09:09
Sam Fredriksson
Thanks for your fast reply
I checked out the swak4foam version as
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x
and the problem is running under
openfoam/2.1.x-20120306
I do not think the 2 multiplyer has something to do with the number of CPU (could it be something with calculating both side of the face). I have now tried with both 16 and 32 wtih the same result.
Since the case I am running is with a solver I have developed from one of the standard solvers I will try to make a simpler case with a standard solver and see if my problems persist.
Regards, Sam
Old   January 8, 2014, 10:09
Sam Fredriksson
I have now used the tutorial channel395 and changed the
system/controlDict as:
libs (
"libOpenFOAM.so"
functions
fieldAverage1
type fieldAverage;
functionObjectLibs ( "libfieldFunctionObjects.so" );
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
UMean
valueType surface;
surface {
type plane;
basePoint (2.1 0 0);
normalVector (1 0 0);
interpolate false;
outputInterval 1;
// zoneName monitoringZone1;
expression "U";
verbose true;
UMean_SUM
valueType surface;
surface {
type plane;
interpolate false;
outputInterval 1;
expression "U";
verbose true;
and constant/polyMesh/blockMeshDict (to make it easier to compare the values) as:
blocks
hex (0 1 3 2 6 7 9 8) (40 25 30) simpleGrading (1 1 1)
hex (2 3 5 4 8 9 11 10) (40 25 30) simpleGrading (1 1 1)
and ran it both in serial and parallel (4 cpus) and get the same kind of problems.
Regards, Sam
Old   January 8, 2014, 12:42
Assistant Moderator
Bernhard Gschaider
Regards, Sam
I don't have time to look at it during the next few days and after some days I usually forget these things. Please open a bug at
http://sourceforge.net/apps/mantisbt...l_bug_page.php
to make sure that it will get looked at. Thanks
PS: the version you're using is the last release. The public development version (the mercurial-repository) might or might not have already a fix for this
Old   January 9, 2014, 02:53
Sam Fredriksson
Ok
https://sourceforge.net/apps/mantisb...iew.php?id=196
//Sam
[OpenFOAM.com] problems running in parallel on Mac OS X and Windows: only 1 cpu windscion OpenFOAM Installation 20 June 5, 2020 16:27
directMapped + regionCoupling + parallel problems elisabet OpenFOAM Running, Solving & CFD 15 October 3, 2018 10:04
[OpenFOAM.org] Problems with using MPIRUN/run cases in parallel in OpenFOAM 4.1 Proportion OpenFOAM Installation 1 August 25, 2017 13:43
MPI parallel meet problems jiaojiao OpenFOAM 1 May 10, 2016 02:30
Problems with "polyTopoChange" on parallel?!? daZigeiner OpenFOAM Programming & Development 0 March 14, 2011 10:05
