[swak4Foam] I have warning in use swak4Foam
Old   October 14, 2013, 07:27
Default I have warning in use swak4Foam
sajad
seju is on a distinguished road
Dear foamer
I want use this code for calculate droplet velocity but I dont kwon any thing.I dont know I must how use it?
its:
downAverage
type swakExpression;
valueType internalField;
variables (
"downDirection=vector(0,-1,0);"//select the downwards direction
"thres=0.5;"//which cells to keep
"liquidVol=sum(alpha1>thres ? vol() : 0);" //calculates the volume of the drop
"downVel=alpha1>thres ? (U & downDirection) : 0;" //a & b:inner vector product. Keep the y component of U. );
expression "downVel*vol()/liquidVol" //vol():vol of the cell
accumulations ( sum ); verbose true;
please help me. I dont know any thing about use swak4Foam,I just found this code in wiki.
http://www.openfoamwiki.net/index.ph...ropletVelocity
seju is offline   Reply With Quote
Old   October 19, 2013, 07:56
sajad
dear foamer
I have compiled swak4Foam 0.2.4 on openFoam 2.2.1;
I want calculate the velocity of bubble or droplet. I added this code to controlDict:
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
downAverage
variables (
expression "downVel*vol()/liquidVol";//vol():vol of the cell
accumulations (
sum
verbose true;
after that in terminal I saw these warning and I dont see change in my simulation.
what do I do?????
warnings are:
sajad@sajad-K55VD:~/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/c4$ cp -r 0/alpha1.org 0/alpha1
sajad@sajad-K55VD:~/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/c4$ setFields
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : setFields
Date : Oct 20 2013
Time : 15:03:08
Host : "sajad-K55VD"
PID : 7262
Case : /home/sajad/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/c4
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
Setting internal values of volScalarField alpha1
Setting field region values
Adding cells with centre within sphere, with centre = (0.21 0.185 0) and radius = 0.0098474
End
sajad@sajad-K55VD:~/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/c4$ interFoam
Exec : interFoam
Date : Oct 20 2013
Time : 15:03:17
PID : 7263
nProcs : 1
Create time
 --> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
No finite volume options present
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.01
Time = 0.01
MULES: Solving for alpha1
Phase-1 volume fraction = 0.998911 Min(alpha1) = 0 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0468969, No Iterations 5
time step continuity errors : sum local = 0.0186152, global = -5.5655e-20, cumulative = -5.5655e-20
DICPCG: Solving for p_rgh, Initial residual = 0.929295, Final residual = 0.0428746, No Iterations 11
time step continuity errors : sum local = 0.01934, global = -1.08697e-19, cumulative = -1.64352e-19
DICPCG: Solving for p_rgh, Initial residual = 0.674363, Final residual = 0.000234574, No Iterations 1001
time step continuity errors : sum local = 1.57286e-05, global = -6.24738e-20, cumulative = -2.26826e-19
ExecutionTime = 15.76 s ClockTime = 16 s
Courant Number mean: 0.0113272 max: 47.3745
deltaT = 0.000105541
Time = 0.0101055
Last edited by wyldckat; October 19, 2013 at 16:55. Reason: Changed [QUOTE] to [CODE][/CODE]
Old   October 19, 2013, 17:01
Retired Super Moderator
Bruno Santos
Greetings seju,
It looks like swak4Foam did not build properly. Run this command to check if the desired library file exists:
ls -l $FOAM_USER_LIBBIN/
If it indicates that there is no such folder or if the folder is empty, then swak4Foam did not build as it was meant to. The correct content should show you at least the file "libswak4FoamParsers.so".
I do suspect that you built swak4Foam as root, which would explain why now you do not have it installed as normal user.
But just in case, please explain how exactly you installed swak4Foam.
Best regards,
Bruno
PS: Please read the instructions from the second link on my signature
edit: I've merged your other thread with this one, namely the first post is from your older thread. This way all can be in the same topic regarding this issue.
Old   October 19, 2013, 18:04
Assistant Moderator
Bernhard Gschaider
Originally Posted by seju View Post
dear foamer
what do I do?????
warnings are:
Seems there was a problem with compiling swak and there is no libsimpleSwakFunctionObjects.so in FOAM_USER_LIBBIN
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 19, 2013, 20:57
sajad
oh,no,oh my god.I run this code: sudo apt-get remove gcc
removed my openFoam.
Old   October 20, 2013, 03:17
Bruno Santos
Why would you need to run that command?
Or a better question: Why did you run that command?
Old   October 20, 2013, 06:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Greetings seju,
Best regards,
Bruno
Added a note about not building as root to the Wiki-page (funny: this wasn't a problem before. Seems like the Zeitgeist is shifting towards "let's build everything as root. Don't care about security")
Old   October 20, 2013, 07:04
sajad
beacuse I want compile openFoam 1.6 ext.
I have a problem.this error was:
linux64Gcc47DPOpt/vorticity
make: Target `application' not remade because of errors.
I thought my gcc had problem.then I removed gcc.removed my openFoam.now I cant compile openfoam 1.6ext and openfoam 2.2.1 removed too
Old   October 20, 2013, 07:18
Bruno Santos
Asking the right questions can get you faster to the right answers
Which Linux distribution are you using?
Old   October 20, 2013, 07:22
sajad
Im using ubuntu 13.04
Old   October 20, 2013, 10:18
sajad
Greetings seju,
Best regards,
Bruno
I installed openfoam 2.2.1 and swak4Foam again,for install swak4foam:
I used this page:https://github.com/wyldckat/swak4foam/tree/OF22X
and in terminal on the openFoam folder I input:
PHP Code:
git clone https://github.com/wyldckat/swak4foam.git
after download it I enter this:
PHP Code:
cd swak4foam
and after that I run
PHP Code:
./Allwmake
.After that I wait for a few min and I saw :
nFOAM/sajad-2.2.1/platforms/linux64GccDPOpt/bin/replayTransientBC
make[1]: Leaving directory `/home/sajad/OpenFOAM/sajad-2.2.1/swak4foam/Utilities/replayTransientBC'
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/sajad/OpenFOAM/sajad-2.2.1/swak4foam/Libraries (most people will be fine without setting that variable)
sajad@sajad-K55VD:~/OpenFOAM/sajad-2.2.1/swak4foam$
after run this code(ls -l $FOAM_USER_LIBBIN) and I saw:
-rwxrwxr-x 1 sajad sajad 1366353 اكتبر 21 17:18 libgroovyBC.so
-rwxrwxr-x 1 sajad sajad 579646 اكتبر 21 17:22 libgroovyStandardBCs.so
-rwxrwxr-x 1 sajad sajad 1784984 اكتبر 21 17:20 libsimpleLagrangianFunctionObjects.so
-rwxrwxr-x 1 sajad sajad 414274 اكتبر 21 17:21 libsimpleSearchableSurfaces.so
-rwxrwxr-x 1 sajad sajad 7187113 اكتبر 21 17:18 libswak4FoamParsers.so
-rwxrwxr-x 1 sajad sajad 249205 اكتبر 21 17:26 libswakChemistryModelFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 1393655 اكتبر 21 17:23 libswakFvcSchemesFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 414856 اكتبر 21 17:26 libswakLagrangianCloudSourcesFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 212460 اكتبر 21 17:22 libswakLocalCalculationsFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 234460 اكتبر 21 17:22 libswakMeshQualityFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 206642 اكتبر 21 17:26 libswakRadiationModelFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 148447 اكتبر 21 17:22 libswakRandomFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 390530 اكتبر 21 17:21 libswakSourceFields.so
-rwxrwxr-x 1 sajad sajad 1071050 اكتبر 21 17:25 libswakSurfacesAndSetsFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 348029 اكتبر 21 17:24 libswakThermoTurbFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 106535 اكتبر 21 17:21 libswakTopoSources.so
-rwxrwxr-x 1 sajad sajad 250266 اكتبر 21 17:24 libswakTransportTurbFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 242345 اكتبر 21 17:26 libswakVelocityFunctionPlugin.so
-rwxrwxr-x 1 sajad sajad 332097 اكتبر 20 20:16 libtecio.so
اکتبر==october
Old   October 20, 2013, 10:39
sajad
PHP Code:
PHP Code:
cd swak4foam
PHP Code:
./Allwmake
اکتبر==october
I cant find funkysetFields?
Old   October 20, 2013, 10:49
Bruno Santos
It's in the applications folder:
ls -l $FOAM_USER_APPBIN
As for installing 1.6-ext:
  1. For being able to use more than one OpenFOAM version, read this: Advanced tips for working with the OpenFOAM shell environment
  2. To build+install 1.6-ext, follow these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_13.04
Old   October 21, 2013, 03:05
sajad
dear bruno
I didnt solve my problem.I added this code in my controlDict but I dont see any change in terminal and simulation.I want calculate velocity bubble or droplet
code is:
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "system";
object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1;
deltaT          0.001;
writeControl    adjustableRunTime;
writeInterval   0.05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.5;
maxAlphaCo      0.5;
maxDeltaT       1;
downAverage     {
variables
"downDirection=vector(0,-1,0);"//select the downwards direction                                  "thres=0.5;"//which cells to keep
expression "downVel*vol()/liquidVol"//vol():vol of the cell
accumulations
sum
verbose true;
Old   October 21, 2013, 04:40
Assistant Moderator
Bernhard Gschaider
dear bruno
code is:
<snip>
maxCo           0.5;
maxAlphaCo      0.5;
maxDeltaT       1;
      downAverage     {
                              variables
                            expression "downVel*vol()/liquidVol"; //vol():vol of the cell
</snip>
"don't see any change": as compared to what? An unmodified case? The original posting?
Anyway:the definition of function Objects should be inside the functions-list (or dictionary). The way you write it OF says "Ah. Interesting. A sub-dicitonary downAverage. Don't know what to do with it so I'll ignore it. On the other hand he didn't define a functions-dictionary. Fine. Less work for me"
Old   October 21, 2013, 06:29
sajad
when I change controlDict I dont see change in terminal in other hands I dont see velocity in terminal and in simulation folder.
source code is
HTML Code:
http://openfoamwiki.net/index.php/Contrib/swak4Foam/Example_dropletVelocity
here cant see definition of function
Old   October 21, 2013, 10:34
Assistant Moderator
Bernhard Gschaider
source code is
HTML Code:
That is right. But that snipplet assumes that you know how to use functionObjects: that such a sub-dictionary has to be inserted into the functions-dictionary (and I think it is a good thing that the author of that snipplet didn't add the enclosing functions-dictionary because that will lead to problem when people insert the second snipplet and wonder why one function-object doesn't work anymore)
Old   October 23, 2013, 03:15
sajad
dear foamer I used this code in controlDict and I have seen error.
 libs (
"libOpenFOAM.so"
downAverage {
 variables (
 "liquidVol=sum(alpha1>thres ? vol()  : 0);" //calculates the volume  of the drop "downVel=alpha1>thres ?  (U & downDirection) : 0;"  //a & b:inner vector product. Keep the  y component of U. );
expression
 "downVel*vol()/liquidVol";//vol():vol  of the cell accumulations ( sum );
 verbose true;
ERROR:
PHP Code:
Build  2.2.1-57f3c3617a2d
Exec
interFoam
Date
Oct 24 2013
Time
10:36:16
Host
"sajad-K55VD"
PID    5804
nProcs
1
sigFpe
fileModificationChecking Monitoring run-time modified files using timeStampMaster
Create time
--> FOAM Warning
    dlopen error
libsimpleSwakFunctionObjects.socannot open shared object fileNo such file or directory
--> FOAM Warning
From function dlLibraryTable::open(const fileName&, const bool)
    could not load
--> FOAM Warning
    dlopen error
libswakFunctionObjects.socannot open shared object fileNo such file or directory
--> FOAM Warning
    could not load
Create mesh for time 0
PIMPLE
Reading field p_rgh
Reading field U
Reading
Reading g
Calculating field g
.h
sum local 0, global = 0cumulative 0
DICPCG
:  Solving for pcorrInitial residual 0, Final residual 0No Iterations 0
Courant Number mean
0 max0
Starting time loop
--> FOAM FATAL ERROR
Unknown function type swakExpression
Valid functions are
4
patchProbes
probes
sets
surfaces
From function functionObject::New(const wordname, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
Old   October 23, 2013, 16:47
Assistant Moderator
Bernhard Gschaider
ERROR:
[PHP]
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Check: probably the libraries are not in your FOAM_USER_LIBBIN-directory (check with "ls $FOAM_USER_LIBBIN"). The reasons for this are usually
- swak did not compile correctly or
- you compiled it as a different user
Old   October 24, 2013, 17:27
sajad
my libraries are:
PHP Code:
sajad@sajad-K55VD:~$ ls $FOAM_USER_LIBBIN
libgroovyBC
.so
.so
.so
.so
libswak4FoamParsers
.so
.so
.so
.so
.so
.so
.so
.so
libswakSourceFields
.so
.so
.so
libswakTopoSources
.so
.so
.so
how can I add libraries in swak and complite swak??
I have to add these libraries to swak because I so need these libraries.
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
