[swak4Foam] OF Installation for Swak4foam + Linux Newbie
Like Tree1Likes
  • 1 Post By gschaider
Old   February 24, 2014, 14:18
Default OF Installation for Swak4foam + Linux Newbie
Richard
RicME85 is on a distinguished road
Im trying to install Openfoam and Swak4foam on Lubuntu so that I can run simulations of my F1 car for the Khamsin Virtual Racecar Challenge, problem is Im new to Linux so most stuff goes straight over my head.
I have been following the guide at - http://www.tfd.chalmers.se/~hani/kur...OwnLaptop.html
I have got to the part of the guide that says:
Close the terminal window, open a new one:
CTRL-ALT-T
and continue:
OF22x
foam
...problem is when I do OF22x I get this:
bash: /opt/OpenFOAM-2.2.x/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-2.2.x/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-2.2.x/etc/config/settings.sh: No such file or directory
bash: /opt/OpenFOAM-2.2.x/etc/config/aliases.sh: No such file or directory
Any ideas?
RicME85 is offline   Reply With Quote
Old   February 26, 2014, 11:30
Assistant Moderator
Bernhard Gschaider
Any ideas?
Check whether /opt/OpenFOAM-2.2.x/bin/ is there (or its parents). Seems that the script and reality are not aligned
BTW: use CODE instead of QUOTE for output in your postings
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 27, 2014, 06:18
Richard
Had a change of plan, decided to go exactly as the guide says in the link I posted in the OP so have an Ubuntu 12.04 LTS install and have got further through the guide than before.
The guide now says to do the following:
Test the installation:
CTRL-ALT_T #To open an new terminal window
OF22x
mkdir -p $FOAM_RUN
run
cp –r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
cd cavity
blockMesh
icoFoam
paraFoam
Problem I have now is this:
richard@laptop:~/OpenFOAM/richard-2.2.x/run$ cp –r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
cp: cannot stat `–r': No such file or directory
cp: omitting directory `/home/richard/OpenFOAM/OpenFOAM-2.2.x/tutorials/incompressible/icoFoam/cavity'
Old   February 27, 2014, 12:13
Assistant Moderator
Bernhard Gschaider
OF22x
mkdir -p $FOAM_RUN
run
cd cavity
blockMesh
icoFoam
paraFoam
This looks like cp on your machine does not support -r (strange). Check the man-page. Maybe -R or --recursive work
Old   February 27, 2014, 16:21
Retired Super Moderator
Bruno Santos
Greetings to all!
Just a quick drive-by to point out a very particular detail... better explained on this Wikipedia article: http://en.wikipedia.org/wiki/Hyphen-minus
  • "-" is a hyphen, which should work just fine on the terminal, such as "cp -r"
  • "−" is a minus sign, which will not work as intended on the terminal (Note: I think it's a minus sign, but I haven't checked the HTML code to confirm this...)
Can't see the difference? Here's side-by-side, where the first one is incorrect:
cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
Always keep in mind that with OpenFOAM and Linux, every single detail, no matter how small, is more important than any other "user friendly interface" leads you to believe
Best regards,
Bruno
PS: It gets worse: http://en.wikipedia.org/wiki/Dash
Old   February 27, 2014, 16:52
Richard
Thank you!
I was copying and pasting into the Terminal so was assuming the guide had everything written correctly, obviously this wasnt the case!
Really appreciate the help.
Old   February 27, 2014, 19:00
Assistant Moderator
Bernhard Gschaider
I've got this sign over my desk "Computers are like an old-testament god: lots of rules and no mercy"
wyldckat likes this.
Old   February 28, 2014, 07:38
Richard
Ok, so I now have OpenFOAM installed
Now to Swak4foam.
This I have zero idea of. Is there a noobs install guide?
Old   February 28, 2014, 07:48
Richard
Just had an attempt at this and here is what I got:
richard@laptop:~$ cd /home/richard/OpenFOAM/ThirdParty-2.2.x/
richard@laptop:~/OpenFOAM/ThirdParty-2.2.x$ svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam
Checked out revision 2035.
richard@laptop:~/OpenFOAM/ThirdParty-2.2.x$ cd swak4Foam
richard@laptop:~/OpenFOAM/ThirdParty-2.2.x/swak4Foam$ nice ./Allwmake
Previously compiled for OpenFOAM
No file 'swakConfiguration'. Python etc won't work. See README for details
Checking swak4Foam-version and generating file
Swak version is 0.3.0
./Allwmake: line 49: wmake: command not found
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
Old   February 28, 2014, 13:10
Assistant Moderator
Bernhard Gschaider
Have you sourced the etc/bashrc of your installation in that shell (either manually or via .bashrc)? Then wmake should be in the path
Old   February 28, 2014, 13:12
Richard
No idea, I'm a complete Linux newbie.
How would I go about doing that?
Old   February 28, 2014, 15:03
Assistant Moderator
Bernhard Gschaider
That is the part in the installation description that says "add a line '~/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc' to your ~/.bashrc" (something in that direction). I'm wondering: on that shell: does it even find (for instance) interFoam? The thing is: installing OF is one thing. But you've got to make sure that a new shell 'knows' where OF is
Old   March 1, 2014, 19:25
Bruno Santos
Greetings to all!
Here's some reading material: http://openfoamwiki.net/index.php/In...with_the_Shell
Best regards,
Bruno
installation Problem - Linux distribution (Not a meshing problem) v_herw Pointwise & Gridgen 2 June 20, 2016 14:47
LINUX newbie with paraView installation problem kenya0514 OpenFOAM Installation 4 January 16, 2013 17:51
Source Pack Installation OpenFOAM Version 2.1.0 on Redhat Linux Indrajit OpenFOAM Installation 1 April 1, 2012 04:39
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
OpenFOAM installation problem on Linux 32bit kumar OpenFOAM Installation 0 April 27, 2007 05:41
