[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 |
March 30, 2014, 08:58 |
Miguel Nóbrega
I'm using Ubuntu 13.10 and I've installed foam extend 3.0, using the deb binary packages available in http://wikki.gridcore.se/foam-extend/download. Then I've tried to download and install swak4foam using the instructions provided in Installation/swak4Foam/Installing On/Ubuntu. I'm getting a very strange basic error, related to some missing files: #################### .... In file included from helpers/printSwakVersion.C:43:0: helpers/printSwakVersion.H:46:21: fatal error: Pstream.H: No such file or directory #include "Pstream.H" ^ compilation terminated. In file included from helpers/switchableNotImplemented.C:43:0: helpers/switchableNotImplemented.H:47:19: fatal error: error.H: No such file or directory #include "error.H" ^ compilation terminated. In file included from helpers/DebugOStream.C:37:0: helpers/DebugOStream.H:55:21: fatal error: Pstream.H: No such file or directory #include "Pstream.H" .... ######################## I've read the all the posts I found about swak4foam installation, and in the Installation/swak4Foam/Understanding Error Messages indicates that OpenFOAM seems to be improperly installed. I followed the recommendation of reading Installation/Working with the Shell, and made all the recommend tests, and all environment variables seem to be OK. Notice that I'm getting the same error in two different computers. One has several OpenFOAM versions and another has just Foam extend 3.0. Additionally, using the find command I found the missing file (or at least one with the same name) in folder: /opt/foam/foam-extend-3.0/src/foam/db/IOstreams/Pstreams. But the compiler cannot figure out this location. Sorry to bother you with this issue, because I believe I'm making a basic mistake. But I cannot figure out which is.... Can you please help me? Cheers, Miguel |
erro, foam extend 3.0, missing files, swak4foam |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 11:51 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
