[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error
Like Tree9Likes
Old   May 22, 2013, 11:30
Default Swak4FOAM 0.2.3 / OF2.2.x installation error
Ferdinand Pfender
FerdiFuchs is on a distinguished road
hello everybody!
im trying to build Swak4FOAM 0.2.3 with:
- OpenFOAM2.2.x
- gcc-4.6.4
- flex-2.5.37
- bison-2.4.1
second run of ./Allwmake gives me the following error/message:
fpfender@sx200:/disk1/users/fpfender/OpenFOAM/source/Swak4Foam_2.x_release_0.2.3$ ./Allwmake
Reading variables from 'swakConfiguration'
Checking swak4Foam-version and generating file
Bison is version 2.4.1
Flex is version 2.5.37 (Minor version: 37)
OpenFOAM-version: Major 2 Minor 2 Patch -1 (-1 == x)
No change to swak4FoamParsers/foamVersion4swak.H
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make: *** [/disk1/users/fpfender/OpenFOAM/fpfender-2.2.x/platforms/linux64Gcc46DPOpt/lib/libswak4FoamParsers.so] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
I dont really know what to do. I got it to work on another machine with a similar constellation:
- OpenFOAM-2.2.x
- gcc-4.6.4
- flex-2.5.35
- bison-2.4.1
FerdiFuchs is offline   Reply With Quote
Old   May 22, 2013, 11:42
Assistant Moderator
Bernhard Gschaider
Originally Posted by FerdiFuchs View Post
hello everybody!
- OpenFOAM2.2.x
- gcc-4.6.4
- flex-2.5.37
- bison-2.4.1
- OpenFOAM-2.2.x
- gcc-4.6.4
- flex-2.5.35
- bison-2.4.1
That is weird. Almost nothing in OF would work without libfiniteVolume.so. Check with "ls $FOAM_LIBBIN" if that variable is pointing to the right location. It also states that you have a swakConfiguration-file. Could it be that something in there breaks the variables for compilation?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 22, 2013, 13:11
Dennis Kingsley
dkingsley is on a distinguished road
Almost everytime I have had a problem with libfiniteVolume.so its been the flex/flex++ definitions under wmake/rules/General that need tweaking for your installed version of flex.
dkingsley is offline   Reply With Quote
Old   May 22, 2013, 13:44
Assistant Moderator
Bernhard Gschaider
With swak too? Because that brings its own rules for flex-files. And I don't see how that should influence the linking phase.
Old   May 22, 2013, 13:58
Dennis Kingsley
my guess is that OpenFOAM 2.2.x did not buillt correctly and libfiniteVolume.so was not created. I have a cluster built on Rocks 5.3.1 which has an old verison of flex that requires changing the rules files. I don't think its a swak problem, it builds just fine on my cluster with OF22x.
EDIT: I just retrieved a new copy of the swak sources from bitbucket and confirmed that it builds against my OF2.2.x that was compiled this morning.
Old   June 13, 2013, 11:19
Ferdinand Pfender
i did it again. the problem was, my openfoam wasnt build correctly.
but now i got a new problem which im trying to solve since days.
compiling Swak4Foam works, with a few errors:
/disk1/users/fpfender/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:210:9: error: ‘class Foam::foreignMeshesFollowTime’ has no member named ‘timeSet’
In file included from /disk1/users/fpfender/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.H:225:0,
                 from manipulatePatchFieldFunctionObject.H:50,
                 from manipulatePatchFieldFunctionObject.C:37:
/disk1/users/fpfender/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C: In member function ‘bool Foam::OutputFilterFunctionObject<OutputFilter>::timeSet() [with OutputFilter = Foam::manipulatePatchField]’:
manipulatePatchFieldFunctionObject.C:51:1:   instantiated from here
/disk1/users/fpfender/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:210:9: error: ‘class Foam::manipulatePatchField’ has no member named ‘timeSet’
make: *** [Make/linux64Gcc46DPOpt/createSampledSetFunctionObject.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [Make/linux64Gcc46DPOpt/createSampledSurfaceFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/expressionFieldFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/clearExpressionFieldFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/addGlobalVariableFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/manipulateFieldFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/addForeignMeshesFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/foreignMeshesFollowTimeFunctionObject.o] Error 1
make: *** [Make/linux64Gcc46DPOpt/manipulatePatchFieldFunctionObject.o] Error 1
/disk1/users/fpfender/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:210:9: error: ‘class Foam::solveLaplacianPDE’ has no member named ‘timeSet’
make: *** [Make/linux64Gcc46DPOpt/solveLaplacianPDEFunctionObject.o] Error 1
Im getting a few more error messages like this. Does anyone know whats this 'timeSet' and how i get rid of it?
thanks a lot!
Old   June 13, 2013, 11:59
Daniel Pielmeier
billie is on a distinguished road
thanks a lot!
It is a new hook to functionObject which was added recently [1] on 2.2.x. I guess swak4foam needs to be adapted to make it build with these new changes but this has not yet happened.
[1] https://github.com/OpenFOAM/OpenFOAM...f57922bec7b80b
billie is offline   Reply With Quote
Old   June 15, 2013, 20:21
Retired Super Moderator
Bruno Santos
Greetings to all!
@Daniel: Many thanks for the report! I've submitted this issue to swak4Foam's bug tracker: https://sourceforge.net/apps/mantisb...iew.php?id=174 - along with the bug fix.
In addition, two notes:
  1. swak4Foam 0.2.4 is already available: http://www.cfd-online.com/Forums/ope...tml#post433484 post #29
  2. Attached is a patch for this version 0.2.4, for compiling with the latest OpenFOAM 2.2.x.
    • Additionally, for those who don't have Git nor SVN ready to be used for getting the latest swak4Foam 0.2.4, feel free to use the ZIP button at the upper left corner of this page: https://github.com/wyldckat/swak4foam/tree/OF22X - it's already patched for building with OpenFOAM 2.2.x.
For applying the attached patch, do the following steps:
  1. Place the attached file inside the main swak4Foam source code folder (version 0.2.4).
  2. Run the following commands:
    gunzip patch_swak2Foam_024_OF22x_49808a1c.gz
    patch -p1 < patch_swak2Foam_024_OF22x_49808a1c
  3. And finally, build swak4Foam:
    ./Allwmake > make.log 2>&1
Best regards,
Bruno
Old   June 17, 2013, 04:14
Daniel Pielmeier
Bruno, thank you very much for the patch. It works perfect.
Old   June 18, 2013, 09:21
Ferdinand Pfender
same here! Thank you very much!
Old   June 18, 2013, 11:50
Assistant Moderator
Bernhard Gschaider
Greetings to all!
Thanks for the report and the fix. I'm still in Korea so answers are a little slow from my side. Fix is pushed to the Mercurial-repository
Old   June 20, 2013, 15:49
Bruno Santos
Greetings to all!
And you're all welcome!
Old   July 31, 2013, 11:26
Raymond.Leoi is on a distinguished road
Does it work for OpenFoam 2.1?
Greetings to all!
Best regards,
Bruno
Raymond.Leoi is offline   Reply With Quote
Old   July 31, 2013, 18:15
Assistant Moderator
Bernhard Gschaider
I think you won't need it there. The problem was introduced by a method added with 2.2.x ... so 2.1 is fine
Old   August 1, 2013, 04:55
Thanks, Bernhard. I wonder where I can directly download the swak4Foam source code? For some reason, the method in wikiOpenfoam didn't work to me.
Old   August 2, 2013, 06:12
Assistant Moderator
Bernhard Gschaider
Which methods did you try and what is the problem? (both repositories - SVN and Mercurial - are up and running)
Old   October 9, 2013, 11:49
Default accessing swake4Foam installed by another user on cluster...
  #17
Jamal
aujamal20 is an unknown quantity at this point
Hello Formers,
My problem is ...
OF 2.2.x is installed on server and one of the users have installed swak4foam0.2.3 in his user_directory. I am trying to use that installation by adding the following line in bash_profile-->
export SWAKFFOAM_SRC= /OpenFOAM/user-2.2.x/lib/Swak4Foam.0.2.3/Libraries
But groovyBC remains unknown.....
waiting for valuable suggestion.
Regards.
aujamal20 is offline   Reply With Quote
Old   October 9, 2013, 16:26
Assistant Moderator
Bernhard Gschaider
Originally Posted by aujamal20 View Post
Hello Formers,
My problem is ...
Regards.
My guess is that you forgot to add the library to the libs-entry.
Or the problem is that swak installs its libraries to FOAM_USER_LIBBIN which is different for different users
Old   October 25, 2013, 12:06
Martin Novák
novakm is on a distinguished road
  • Attached is a patch for this version 0.2.4, for compiling with the latest OpenFOAM 2.2.x.
Hi Bruno.
Thanks for the patch
I ve noticed problems together with moving meshes. Specially with dynamicTopoFvMesh (Sandeep Menon). The problem was in file ../simpleFunctionObjects/lnInclude/simpleFunctionObject.H at line 177.
#ifdef FOAM_FUNCTIONOBJECT_NEEDS_UPDATEMESH
    // make functionObject happy but fail because this is not an implementation
    virtual void updateMesh(const mapPolyMesh&) {
        notImplemented("simpleFunctionObject::updateMesh");
    virtual void movePoints(const polyMesh&) {
        notImplemented("simpleFunctionObject::movePoints");
#endif
It causes crashes of the computation.
By erasing the notImplemented stuff (sandeep's suggest) the problem seems to be solved.
#endif
Hope, this helps somebody. (Much more hope it will not have any influence on the results )
Best regards
Martin
novakm is offline   Reply With Quote
Old   October 26, 2013, 05:52
Bruno Santos
Hi Martin,
Many thanks for sharing! I've reported this to the bug tracker for swak4Foam: https://sourceforge.net/apps/mantisb...iew.php?id=190 - this way Bernhard feels a bit more obligated to fix it
By the way Martin, please provide a simple test case at that bug report, so that Bernhard can reproduce the problem!
Best regards,
Bruno
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
