June 12, 2014, 09:15 |
pulseitzDaily - problem
Tommy Sp
Rep Power: 12 |
Hello!
swak4Foam just installed on my computer. Use the openfoam 2.2.2. When I type blockMesh, the mesh is generated normally, but when I type "oodles", which is described in "application oodles" in ControlDict, "command not found" appears .. where am I missing guys? Thank you for your attention! |
June 12, 2014, 10:02 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 12, 2014, 10:14 |
Tommy Sp
Rep Power: 12 |
June 12, 2014, 10:20 |
Tommy Sp
Rep Power: 12 |
I replaced 'oodless' by 'pisoFoam' in application (application pisoFoam) within ControlDict ..
when I typed "pisoFoam" in the terminal, these errors above occurred |
June 12, 2014, 11:02 |
Tommy Sp
Rep Power: 12 |
Anyone know how should I do to run this example? thanks!
June 12, 2014, 12:20 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 12, 2014, 12:42 |
Tommy Sp
Rep Power: 12 |
Strange that. I tried to simulate using the proper files I downloaded from swak4Foam. I'll try to install an older version of OpenFOAM version v2.1 ... and try to reinstall swak4Foam
June 12, 2014, 15:10 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
How did you download it? hg, svn or the tarball?
June 12, 2014, 15:23 |
Tommy Sp
Rep Power: 12 |
svn...from this link:
http://openfoamwiki.net/index.php/In...am/Downloading and type this code within the terminal: Code:
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam I followed the steps according to this link (to install swak4Foam): http://openfoamwiki.net/index.php/In...10.04_to_14.04 I then replaced 'oodles' for 'pisoFoam' in "ControlDict" for this case, on the original folder (directory: home/swak4Foam/swak4Foam_2.x/Examples/groovyBC/pulsedPitzDaily) .. and when executing the terminal (after using blockmesh and checkMesh) for pulsedpitzDaily case, I typed 'pisoFoam' on the terminal and still remain showing this error. my ubuntu is quantal 12.10 and I have openfoam 2.2.0 on one computer and openfoam 2.2.2 on another computer detail: I created a folder in "home" (in ubuntu) with the name "swak4Foam" and typed the line to download (svn) in this directory. not copied anything to the folders openfoam. |
June 12, 2014, 15:40 |
Tommy Sp
Rep Power: 12 |
after installed I typed in the terminal 'funkySetFields' (to verify that the installation was done successfully) and this appeared:
sp@sp-945GCM-S2C:~$ funkySetFields /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : funkySetFields Date : Jun 12 2014 Time : 16:35:06 Host : "sp-945GCM-S2C" PID : 16773 Case : /home/sp nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // swakVersion: 0.3.0 (Release date: 2014-01-24) // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // --> FOAM FATAL ERROR: funkySetFields: time/latestTime option is required From function main() in file funkySetFields.C at line 643. FOAM exiting sp@sp-945GCM-S2C:~$ |
June 12, 2014, 16:29 |
#11 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I tried the svn. Seems like the symbolic link was not pulled. Maybe it is not in the repository. Just create a link to the original residualTime-file and it should work OK
June 12, 2014, 17:00 |
#12 |
Tommy Sp
Rep Power: 12 |
thanks bro!
June 17, 2014, 16:18 |
#13 | |
Pratik Nanavati
Rep Power: 12 |
root@ubuntu:/opt/openfoam220/swak4Foam_2.x_release_0.2.1# funkySetFields /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : funkySetFields Date : Jun 17 2014 Time : 22:02:59 Host : "ubuntu" PID : 3599 Case : /opt/openfoam220/swak4Foam_2.x_release_0.2.1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // swakVersion: 0.3.0 (Release date: 2014-01-24) // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // --> FOAM FATAL ERROR: funkySetFields: time/latestTime option is required From function main() in file funkySetFields.C at line 643. FOAM exiting You have explained, 'Seems like the symbolic link was not pulled. Maybe it is not in the repository. Just create a link to the original residualTime-file and it should work'. But I am not able to interpret what you are trying to say, as i am a beginner. Can you please suggest some solution for my error ? Thanks. |
June 17, 2014, 16:53 |
#14 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 17, 2014, 17:52 |
#15 | |
Pratik Nanavati
Rep Power: 12 |
Hello, Thanks for the reply. I have gone through the post which mentioned. However I have few very basic Questions about the system of swak4foam. I tried to search it back and forth on every forum but couldn't find the answers. Please Just let me know Correct or Not Correct. 1. I have Installed OF 220 as a normal user. 2. swak4foam installed as ROOT. is it okey ? 3. swak4foam folder is placed in /opt/openfoam220/swak4foam. is it the right folder ? or it should be in home/openfoam ? 4. Can you post a link of Complete Example in which swak4foam is being used. (What I wanted to know here is, which kind of symptoms the results have for the swak4foam?) Thanks. |
June 18, 2014, 09:07 |
#16 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
swak4Foam-folder can be anywhere Example: there are enough presentations on the swak-page on the Wiki that do exactly that (the PennState or the Jeju-presentations are good starting points). I am already repeating myself there. So I won't do that here
January 27, 2015, 04:16 |
#17 |
Pratik Nanavati
Rep Power: 12 |
July 14, 2015, 10:14 |
#18 | |
Syavash Asgari
Rep Power: 18 |
Dear Bernhard, When I try to run the pulsedPitzDaily example, I get the following error. Please help me to resolve this problem. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-262087cdf8db Exec : pisoFoam Date : Jul 14 2015 Time : 18:37:39 Host : "syavash-VPCF11DGX" PID : 32738 Case : /home/syavash/OpenFOAM/swak4Foam_2.x/Examples/groovyBC/pulsedPitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy Selecting LES delta type cubeRootVol --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable bounding k, min: 0 max: 2e-05 average: 2e-05 oneEqEddyCoeffs { ck 0.07; ce 1.05; } Starting time loop --> FOAM Warning : From function solvePDECommon::read(const dictionary& dict) in file solvePDECommon.C at line 169 If in case of relaxation you want to relax the last iteration as well set 'relaxLastIteration true;' in "/home/syavash/OpenFOAM/swak4Foam_2.x/Examples/groovyBC/pulsedPitzDaily/system/controlDict.functions.distance" --> FOAM Warning : From function Foam::solvePDECommon::fvOptions() in file solvePDECommon.C at line 100 No 'fvOptions' found. Returning dummy (no further warnings --> FOAM FATAL ERROR: incompatible dimensions for operation [distance[0 1 -1 0 0 0 0] ] + [constantscalar[0 -1 0 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&) in file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1356. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::DimensionedField<double, Foam::volMesh> const&, char const*) at ??:? #3 Foam::tmp<Foam::fvMatrix<double> > Foam::operator+<double>(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::tmp<Foam::fvMatrix<double> > const&) at ??:? #4 Foam::solveLaplacianPDE::solve() at ??:? #5 Foam::solvePDECommon::solveWrapper() at ??:? #6 Foam::solveLaplacianPDE::solveLaplacianPDE(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) at ??:? #7 Foam::OutputFilterFunctionObject<Foam::solveLaplacianPDE>::allocateFilter() at ??:? #8 Foam::OutputFilterFunctionObject<Foam::solveLaplacianPDE>::start() at ??:? #9 Foam::functionObjectList::read() at ??:? #10 Foam::Time::run() const at ??:? #11 Foam::Time::loop() at ??:? #12 at ??:? #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #14 at ??:? Aborted (core dumped) Syavash |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
