[swak4Foam] groovyBC for extrapolation
Like Tree2Likes
  • 1 Post By gschaider
Old   September 16, 2014, 05:58
Default groovyBC for extrapolation
T. Chourushi
Tushar@cfd is on a distinguished road
Dear ALL,
I wish to extrapolate internal fields on to the Wall Boundary condition instead of zeroGradient condition.
The following extrapolation I wish to use:
tau[wall] = average(tau) - average(normal)*(Sum( (normal[i]-average(normal))*(tau[i]-average(tau)) )/ Sum (pow((normal[i]-avg(normal)),2) )
where, i depends on the number of neighbouring faces surrounding the cell centre near the wall patch;
normal[i] are the distance of face centres (tau[i]);
Sum depends on the i;
average(tau) is the mean of tau[i];
average(normal) is the mean of normal[i];
How would I progress for the same?
Thanks in Advance!
Tushar@cfd is offline   Reply With Quote
Old   September 17, 2014, 17:22
Assistant Moderator
Bernhard Gschaider
Originally Posted by Tushar@cfd View Post
Dear ALL,
Thanks in Advance!
internalField(tau) gives you a field with the values of the cells next to the patch. All the other things (average, sum, normal(), pow) are named exactly the way you wrote them
nimasam likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 19, 2014, 00:56
T. Chourushi
Thanks a million Bernhard,
You mean to say I should use the following expression
type groovyBC;
variables "taui=internalField(tau);normali=internalField(nor mal());";
valueExpression "tau = average(tau) - average(normal())*(Sum( (normali-average(normal()))*(taui-average(tau)) )/ Sum (pow((normali-average(normal())),2) )";
Please correct me if I am wrong
Old   September 23, 2014, 13:48
Assistant Moderator
Bernhard Gschaider
type groovyBC;
sum should be lower-case. But looks alright apart from that
Tushar@cfd likes this.
Old   March 14, 2015, 03:09
Ehsan Mahravan
EhsanMh is on a distinguished road
type groovyBC;
Dear Tushar & Bernhard
I want to use extrapolation you explained here, but when i use the following code:
variables "pi=internalField(p); normali=internalField(normal());";
i get the following error:
--> FOAM FATAL ERROR:
Parser Error for driver PatchValueExpressionDriver at "1.15-20" :"syntax error, unexpected TOKEN_normal"
"internalField(normal())"
EhsanMh is offline   Reply With Quote
Old   September 23, 2015, 16:14
Minisasi is on a distinguished road
I want to impose on my boundary something like:
 T_b = T_s/5
where
T_b is the temperature at my boundary
T_s is the temperature at the position S .
Is there a way to extrapolate that value at S, and impose it at the boundary?
Thank you in advance,
Cheers
Minisasi is offline   Reply With Quote
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
