October 7, 2014, 06:33 |
install: "PYTHONPATH is not set"?
sajad
Rep Power: 12 |
hi
when I write pyFoamVersion.py is terminal : Code:
sajad@sajad-pc:~/PyFoam$ pyFoamVersion.py Machine info: Linux | sajad-pc | 2.6.32-66-generic-pae | #132-Ubuntu SMP Mon Sep 1 18:51:21 UTC 2014 | i686 | Python version: 2.6.5 (r265:79063, Feb 27 2014, 19:44:14) [GCC 4.4.3] Python executable: /usr/bin/python PYTHONPATH is not set Location of this utility: /usr/local/bin/pyFoamVersion.py PyFoam WARNING on line 175 of file /usr/local/lib/python2.6/dist-packages/PyFoam/FoamInformation.py : Basedir /home/sajad/foam for fork extend does not exist or is not a directory Version (2, 0, 1) Fork openfoam of the installed 2 versions: openfoam-201 : /opt/openfoam201 openfoam-210 : /opt/openfoam210 pyFoam-Version: 0.6.3 Path where PyFoam was found (PyFoam.__path__) is ['/usr/local/lib/python2.6/dist-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/sajad/.pyFoam/pyfoamrc'), ('directory', '/home/sajad/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : No Not used. Maybe will by used later to spped up parts of PyFoam cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : Yes ipdb : No Not necessary. Only makes debugging more comfortable IPython : No Not necessary. But the interactive shell may be more comfortable matplotlib : No Only Gnuplot-plotting possible mercurial : No Not a problem. Used for experimental case handling nose : No Only needed for running the unit-tests (developers only) Numeric : No Not supported anymore. No need to install it numpy : Yes version: 1.3.0 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced) pandas : No Not a problem. Only used for handling of advanced data-handling ply : No Not a problem. Version from ThirdParty is used profile : No Not a problem. Can't profile using this library psyco : Yes version: 17170672 PyQt4 : No Only some experimental GUI-stuff relies on this PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : No Not yet used. Possibly use signal-fitting etc Tkinter : No Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations twisted : Yes version: 10.0.0 vtk : No Not a problem. Only used for some utilities xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files Library locations cProfile : /usr/lib/python2.6/cProfile.pyc hotshot : /usr/lib/python2.6/hotshot/__init__.pyc numpy : /usr/lib/python2.6/dist-packages/numpy/__init__.pyc psyco : /usr/lib/python2.6/dist-packages/psyco/__init__.pyc twisted : /usr/lib/python2.6/dist-packages/twisted/__init__.pyc sajad@sajad-pc:~/PyFoam$ ^C my question is this an error?is this a problem?if yes how can I set PYTHONPATH? Last edited by wyldckat; October 11, 2014 at 16:34. Reason: Added [CODE][/CODE] |
October 11, 2014, 16:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sajad6,
From what I can see, that's only a warning, not an error message. Because even without that environment variable being defined, PyFoam is installed in the main Python library folder, therefore there was no problem. Best regards, Bruno
Install openFOAM from with proxy server | Dhruval | OpenFOAM Installation | 3 | October 18, 2014 15:38 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
