[flameletFoam] flameletFoam (by Hagen Müller)
Like Tree27Likes
Old   December 11, 2014, 12:19
Default flameletFoam (by Hagen Müller)
Hagen Müller
Hagen is on a distinguished road
Dear all,
I would like to open a thread for the flameletFoam package we recently developed. This is a package to use the steady laminar flamelet model for turbulent non-premixed combustion in OpenFOAM.
The package consists of a cantera tool to calculate the laminar flamelets, an utility to integrate them with a beta-PDF and a solver for RANS and LES. Two versions are available - one for OF-2.3 and one for OF-2.1.
Download: https://github.com/flameletFoam/
Documentation: https://openfoamwiki.net/index.php/E...n/flameletFoam
Greetings, Hagen
Hagen is offline   Reply With Quote
Old   December 19, 2014, 20:03
Freedom
wenxu is on a distinguished road
We Can use any reaction mechanism in cantera. We just need to provide it in The mechanism folder ans select it in The input.txt.
------by Hagen Müller
wenxu is offline   Reply With Quote
Old   December 20, 2014, 02:56
Freedom
Dear Hagen,
http://www.et.byu.edu/~Tom/classes/6...ningphases.pdf we can get Cantera as the instructions, but can not be used by OF.
Now i want to get CO mechanism of .xml file as gri30.xml in the mechanisms folder, how can i get it? I have no idea. Please give me some hints, Thank you in advance!
Best regards,
wenxu
Old   December 21, 2014, 13:02
Hagen Müller
Dear Wenxu,
which mechanism do you want to use?
There are some provided in the cantera installation folder (cantera-2.0.0/data/).
If you have your mechanism in chemkin format, there is a converter ck2cti. I haven't tried it though.
Hope this helps a bit,
Hagen
Old   December 22, 2014, 04:48
Freedom
The different versions were used, i think. The first version fvOptions was not added, but the latter one, fvOptions was added to adjusted to OF230.
Dear Hagen,
Yes, i have found that the ck2cti can transfer .inp file to .cti file, which can be used in cantera. But my problems as follows:
  1. I want use gri30 for CO reaction, but i'm not sure if that ok.(gri30 if for natural gas, but the CO is the intermediate specie, so i think it ok, if i'm wrong, please correct me.)
  2. If the first one is ok, then i set the input.txt as follows for CO:
    1.013e5 // operating pressure in Pa
    294 // Temperature at the left boundary in K
    294 // Temperature at the right boundary in K
    294 // Temperature for equilibrium solution calculation
    0.05 // mass flow in kg/(s m^2)
    0.287 // Stoichiometric Mixture fraction Zst
    CO:0.99999,AR:0.00001 // Species at the left side (in mole fractions)
    O2:0.21,N2:0.79 // Species at the right side (in mole fractions)
    mechanisms/gri30.xml // Location of the chemical mechanism
    0.2 // domain lenght [m]
    50 // Initial number of grid point
    100 // Maximum number of grid points (applies only for grid refinement)
    1 // Refine grid? (1 = true , 0 = false)
    If i use the initial solution file (this file is actually for CH4),then it will give the :
    Take 5 timesteps 6.407e-05 3.603
    Attempt Newton solution of steady-state problem... failure.
    which means that the counterflow has been extincted? Then i change the mass flow to very low, such as 0.0001, then the output is as something like above:
    Take 10 timesteps 0.001847 3.423
  3. If i do not use the initial solution file, then it ask me to set the equivalence ratio phi (0 - 1), but the equivalence ratio of CO is 2.48, which is not within (0-1),then it will ask me to put the name of the fuel (only CH4 and H2 can be selected.): if now i put CO, as excepted, the error is as follows:
    Your fuel/oxidizer selection is not available
    Please add your combination in the source code
So it seems that CO can not be used by ./flamelet, please help me?
PS: the flamelet.cpp file in src folder should be changed in order to use CO mechanism. If that true, then it will be tough... Sorry, this question is some one like the first, because i am not understand the first time you answer me.
regards,
wenxu
Last edited by wyldckat; December 27, 2014 at 05:22. Reason: merge consecutive posts, posted a few minutes apart
Old   December 23, 2014, 08:31
Freedom
Then no one help me?!
Old   January 5, 2015, 06:36
Hagen Müller
Dear Wenxu,
your cantera run does not converge with these settings. If you are using one of the solution files in the examples folder, you can try to change the boundary conditions in the input.txt in small steps. In your case, if you are using the Sandia example, slowly increase the CO mass fraction and decrease mass fraction of the other species at the fuel boundary until you reach the conditions of your flame.
Hagen
Old   April 7, 2015, 12:32
Default flameletFoam compilation problem
Uyan is on a distinguished road
I am using openfoam-2.3.x [ on ubuntu 1.204] and i tried to install flameletFoam. when i try to compile OpenFOAM
i get an error about cycilcAMILduInterface
finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/flameletFoamPost.o] Error 1
Has anyone come across something like that and solved it?
Uyan is offline   Reply With Quote
Old   April 7, 2015, 16:13
Default cycilcAMILduInterface.H error
Well i managed to get it compiled, but did not test yet.
I had to replace few Make/options files
src/combustionModels/Make/options
applications/utilities/preProcessing/canteraToFoam/Make/options
applications/utilities/postProcessing/flameletFoamPost/Make/options
I added the following include directory
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
Old   April 13, 2015, 06:47
Hagen Müller
Hi Uyan,
thank you! I changed the source in the git repository.
Regards, Hagen
Old   July 25, 2015, 16:42
Default Error after "make"
  #11
Lisandro Maders
Lisandro Maders is on a distinguished road
Ps: I edited it because I had put I had an error when compiling Cantera. Actually, I compiled Cantera successfully, I had an error when compiling flameletFoam solver..
Hello guys,
I am installing Cantera aiming use it with OpenFOAM. However, when I tried to compile the flameletFoam solver (after "make" command), I received the following error:
g++ -g -Wall -fpermissive -c StFlow_2.cpp -I/usr/local/include
In file included from StFlow_2.h:10:0,
from StFlow_2.cpp:15:
TransportBase_2.h:344:57: error: ‘virtual’ outside class declaration
DEPRECATED(virtual void mobilityRatio(double* mobRat)) {
TransportBase_2.h:344:58: warning: ISO C++ forbids declaration of ‘DEPRECATED’ with no type [-fpermissive]
TransportBase_2.h: In member function ‘int Cantera::Transport:EPRECATED(void (*)(double*))’:
TransportBase_2.h:346:5: warning: no return statement in function returning non-void [-Wreturn-type]
In file included from StFlow_2.cpp:15:0:
StFlow_2.h: At global scope:
StFlow_2.h:195:18: error: conflicting return type specified for ‘virtual void Cantera::StFlow::save(Cantera::XML_Node&, const doublereal*)’
virtual void save(XML_Node& o, const doublereal* const sol);
In file included from StFlow_2.h:11:0,
/usr/local/include/cantera/oneD/Domain1D.h:413:23: error: overriding ‘virtual Cantera::XML_Node& Cantera:omain1D::save(Cantera::XML_Node&, const doublereal*)’
virtual XML_Node& save(XML_Node& o, const doublereal* const sol);
make: *** [StFlow_2.o] Error 1
Does anyone have any idea what could be causing this?
Thanks in advance!
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   July 26, 2015, 14:28
Federica Ferraro
federicafer is on a distinguished road
Hi Lisandro,
If you are using cantera-2.0.0 you should not have any problem.
that is my output to make:
g++ -g -Wall -fpermissive -c StFlow_2.cpp -I/opt/cantera/include
g++ -g -Wall -fpermissive -c TransportFactory_2.cpp -I/opt/cantera/include
g++ -g -Wall -fpermissive -c Lewis1Transport.cpp -I/opt/cantera/include
g++ -c -g -Wall -fpermissive flamelet.cpp -I/opt/cantera/include
g++ flamelet.o StFlow_2.o TransportFactory_2.o Lewis1Transport.o -lf2c -pthread -L/opt/cantera/lib -lcantera -lcvode -lblas -llapack -o flamelet
the paths to cantera's include and libraries (in bold) are different for you.. this can probably cause the error..
Check if the first line in the Makefile contains the path to your cantera build directory that for me is
include ~/cantera-2.0.0/build/platform/Cantera.mak
Regards,
Federica
federicafer is offline   Reply With Quote
Old   July 26, 2015, 18:05
Default Sorted the old problem, a new one appeared..
  #13
Lisandro Maders
Federica,
thanks for your reply! I was really making a mistake regarding to the path.
Also, I wrote my thread badly. My error happened when I compiled the flameletFoam solver, not Cantera. I sorted it out by updating the pip through easy_install. It seems that for Ubuntu 12.04 (which I am using) the pip (for python packages) has some bugs (see it on http://stackoverflow.com/questions/2...-on-pip-freeze)
So I uninstalled Cantera, updated pip, reinstalled Cantera and then the flameletFoam compiled well.
The only thin weird was when I runned scons test after building, it shown me this error:
* Running test 'diamondSurf-cti'... Comparing 'diamond_blessed.xml' with 'diamond.xml' scons: *** [test_problems/diamondSurf/.passed-diamondSurf-cti] /private/tmp/cantera-OaWCVw/cantera-2.1.2/test_problems/diamondSurf/diamond.xml: No such file or directory scons: building terminated because of errors.
However, as it was running everything ok (apparently) I did not fixed it. Do you know if this is really an error or just a test stuff bug? Could I keep using Cantera with this error?
Regards,
Lisandro
zhouqy1994 likes this.
Old   September 10, 2015, 20:40
knuckles is on a distinguished road
Can anyone explain to me why the steady laminar flamelet model class is templated as YSLFModel<class CombThermoType, class ThermoType>? It seems to me that the second template variable is completely irrelevant. I was able to remove it by:
  1. eliminating the second template variable from YSLFModel.H and .C
  2. changing the macro call in YSLFModels.C to makeCombustionTypes() rather than makeCombustionTypesThermo(), and removing the third macro argument
  3. changing the combustionModel entry in constant/combustionProperties of the case file to YSLFModel<rhoThermoCombustion> - i.e., removing the second template variable
This compiled and ran successfully. Have I unknowingly introduced an error?
Edit: this was for OpenFOAM 2.3.0
knuckles is offline   Reply With Quote
Old   September 23, 2015, 04:26
Hagen Müller
Thanks for this hint! The ThermoType template is indeed a remnant of an older version and is not needed anymore. I changed the code as you suggested and pushed it to the git repository.
Old   May 23, 2016, 12:58
elainest is on a distinguished road
hi,
I have the same problem with thalhah90.
In the terminal (in ~/OpenFoam/flameletFoam/tutorial/pilotDiffusionFlame/les directory), canteraToFoam: command not found.
Could anyone help us?
Thanks in advance!
elainest is offline   Reply With Quote
Old   June 1, 2016, 07:26
Yedukrishnan P
yedu is on a distinguished road
Same problem as above. Can anyone help please. Also, blockMesh is creating erroneous log files for canteraToFoam.
yedu is offline   Reply With Quote
Old   June 7, 2016, 22:45
Thalhah
thalhah90 is on a distinguished road
I finally have flameletFoam working!
Installing OpenFoam 2.1.x instead of 2.3.0 apparently solves the problem.
Not sure why the latter version didn't work though..
thalhah90 is offline   Reply With Quote
Old   June 8, 2016, 03:47
Yedukrishnan P
So, does flameletFoam and cantera work in 2.1.x as well?
Old   June 8, 2016, 06:08
Tobi's Avatar
Tobias Holzmann
Of course, if not, you have do manipulate the code that it works.
Alternatively you can use the flameletModel based on the research by CRECK Modelling. Check out my homepage for further information, I converted it to different versions and made further improvements.
PS: Cantera does not belong to FOAM.
Keep foaming,
Tobias Holzmann
[flameletFoam] new flameletFoam for OpenFoam-2.3.0 Likun OpenFOAM Community Contributions 25 April 10, 2017 03:05
[flameletFoam] Issue: Installation of flameletfoam Raghuveera OpenFOAM Community Contributions 2 April 12, 2016 22:59
FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables Sermengi OpenFOAM 2 December 19, 2014 06:10
flameletFoam for mutiphase Combustion wenxu OpenFOAM 0 December 10, 2014 08:14
data on flow Hagen Poisseuis kostas FLUENT 0 August 6, 2003 17:37
